Results 181 to 195 of 275
Thread: Mercury 1994 2.0L 150
06-23-2018, 08:06 AM #181
Yes u r correct. Also have a extra pump
06-23-2018, 12:28 PM #1825000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
07-02-2018, 08:07 PM #1835000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Well, it’s hard for me to believe, but this is the first step in reassembly. Wasn’t sure this would actually happen.
This is the new power trim unit. It’s from a 1997 so it’s a 2-wire instead of the three wire. It took me a while to figure out (from posts) that the polarity of the two wires are just switched for changing the direction up or down. This just didn’t seem right (or intuitive) to not have a fixed ground, but it actually makes testing a bit more convenient. Guess I’ll have to get a harness with the relays instead of using the solenoids that came with the motor.
In any case the question is, on the new trim unit, in the full down position the two smaller rams do not go down. Is it the weight of the engine that would normally cause this to happen? Is this normal behavior for the unit without the engine installed?
07-02-2018, 08:42 PM #1845000 RPM
- Nov 2016
- Snohomish, WA
- 203
- 15
- 9
- 16
Yes, they’ll move with the engine weight. I had mine able to move by hand before, but I was flushing the water out of it when the PO had installed the wrong lift support and it broke my reservoir. I noticed the main ram would go down and force them up. When full of fluid, they were fully extended and tight.
Glastron1987 thanked for this postGlastron1987 liked this post
07-02-2018, 08:55 PM #185
no so... they should move thru tha whole range up and down, power head are not..... tha big one is "tilt only" will not hold motor under any power.. tha trim rods do all tha work.
07-02-2018, 08:58 PM #1865000 RPM
- Nov 2016
- Snohomish, WA
- 203
- 15
- 9
- 16
Tight, but not impossible I should say. Try pushing harder.
07-02-2018, 09:01 PM #1875000 RPM
- Nov 2016
- Snohomish, WA
- 203
- 15
- 9
- 16
07-02-2018, 09:08 PM #188
I also thought the 2 small rams do all the trimming from down position up till big ram (tilt) takes over ,but big ram will not raise it under power(past point of 2 small rams)
07-02-2018, 11:08 PM #1895000 RPM
- Nov 2016
- Snohomish, WA
- 203
- 15
- 9
- 16
I think I misunderstood. I thought you were trying to move them by hand in bypass since you didn’t have the solenoids. Reading closer, were you actuating it with the pump motor?
07-03-2018, 03:23 AM #190
I have a couple sets of relays with harnesses.
07-03-2018, 06:14 AM #1915000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
That was hooking the motor to a car battery with jumper cables to test it out going up and down. The two small rods never went in at the full down position. I'll try again giving it a hand. Externally the unit looks great; hard to believe there would be an internal problem, unless a weak motor could behave like that, but the big ram goes up and down fine. Although the fluid may be old, there is plenty of fluid in it.
07-03-2018, 10:51 AM #192
you should be able ta lay tha unit ona bench and run it thru its paces.. both trim rods and tilt should completely cycle thru, up, down, in, out no mater what if its right... its a "closed system".. it pushes and pulls all three ... only time any weight will come inta play is if weight its "pushing" or "pulling" is to much over its limits...….
07-03-2018, 02:29 PM #1935000 RPM
- Nov 2016
- Snohomish, WA
- 203
- 15
- 9
- 16
07-03-2018, 02:32 PM #1945000 RPM
- Nov 2016
- Snohomish, WA
- 203
- 15
- 9
- 16
07-03-2018, 03:42 PM #195
so much for tha way I've tested 'em ona stand with justa clamp n saddle (it must be a lot heavier than it looks)... layin' ona bench naked then, huh!... been fooled a lotta years I guess... what tha hell, its a merc!
Glastron1987 thanked for this postnitro_rat liked this post
1994 Mercury 2.5 260 Rebuild
By Rock Steady in forum Technical DiscussionReplies: 19Last Post: 07-30-2022, 06:03 PM -
1994 Mercury Pro Max rigging
By Warrenroadie in forum Technical DiscussionReplies: 32Last Post: 02-17-2017, 04:01 AM -
Mercury Tech: 1994 2.5 200HP Mercury EFI XR
By FL_Sanger_Barefooter in forum Technical DiscussionReplies: 7Last Post: 06-26-2016, 08:20 AM -
Mercury Tech: 1994 Mercury 175 2.5 oil conversion
By Liberator225 in forum Technical DiscussionReplies: 2Last Post: 04-23-2012, 07:10 AM -
Need Some info on 1994 Mercury 200 xri
By cheapbeater in forum Technical DiscussionReplies: 3Last Post: 04-16-2009, 10:20 AM
