Results 136 to 150 of 275
Thread: Mercury 1994 2.0L 150
05-21-2018, 12:46 PM #136
Mig a nut to the top. Just set it up there and fill up the center with weld. Should turn out easy once it cools down...
Josh Peterson
Glastron1987 thanked for this postGlastron1987 liked this post
05-21-2018, 02:16 PM #137Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Show us where the studs were so securely bonded, fused. Could you knock them out with a punch?
05-21-2018, 07:49 PM #1385000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Not sure how they can get punched out as they are srewed in.
I like the ideas of pipe wrench, grinding a flat spot for better grip with visegrips or pipe wrench, or welding the nut on.
Probably won't be able to try until the weekend.
05-21-2018, 07:57 PM #139
The holes in the mid are not threaded. You should be able to drive them down and out.
05-21-2018, 08:00 PM #140
05-21-2018, 08:24 PM #1415000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Oh yeah, the powerhead ones are what I was referring to, but now that you mention it I should clear those out too, eventually.
05-21-2018, 08:38 PM #142Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
That was the root of the problem wasn't it?
05-21-2018, 08:39 PM #143
Fmp was referring to studs that you cut that are still in midsection.
05-21-2018, 08:44 PM #144Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Yes the unwanted anchors
05-21-2018, 08:47 PM #145
In my opinion they are threaded too much. They always corrode in the threads above the nut.
05-22-2018, 09:17 AM #146
powerhead studs are fine thread at the bottom and coarse thread where they screw into powerhead. That is why they usually thread out of block pretty easy.
05-22-2018, 09:36 AM #147
Glad you finally got it apart.
It's funny how the water wicks it's way up the threads over time and causes corrosion.
05-24-2018, 08:01 PM #1485000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
The studs did come out of the block pretty easy. A medium sized monkey wrench was the ticket. A smaller one would have done but I didn’t have one. Must be the threads as Bullet123 said. I was happy about finally getting something easy to do.
To get the remaining pieces out of the mid-section a punch worked for all by the two more forward long ones. They seem welded in.
05-24-2018, 08:22 PM #149Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Buggers
05-25-2018, 12:22 AM #150
My Daddy taught me never force anything, just get a bigger hammer..
1994 Mercury 2.5 260 Rebuild
By Rock Steady in forum Technical DiscussionReplies: 19Last Post: 07-30-2022, 06:03 PM -
1994 Mercury Pro Max rigging
By Warrenroadie in forum Technical DiscussionReplies: 32Last Post: 02-17-2017, 04:01 AM -
Mercury Tech: 1994 2.5 200HP Mercury EFI XR
By FL_Sanger_Barefooter in forum Technical DiscussionReplies: 7Last Post: 06-26-2016, 08:20 AM -
Mercury Tech: 1994 Mercury 175 2.5 oil conversion
By Liberator225 in forum Technical DiscussionReplies: 2Last Post: 04-23-2012, 07:10 AM -
Need Some info on 1994 Mercury 200 xri
By cheapbeater in forum Technical DiscussionReplies: 3Last Post: 04-16-2009, 10:20 AM
