Results 91 to 105 of 275
Thread: Mercury 1994 2.0L 150
04-21-2018, 04:08 PM #91Scream And Fly VIP
- Jul 2013
- California
- 1,555
- 21
- 63
- 83
- 294
Must be a salt water motor.
I’ve had some so bad used a portable plasma cutter and destroyed the exhaust plate getting the powerhead off.
Does your new mid have the exhaust plate?
Glastron1987 thanked for this postGlastron1987 liked this post
04-21-2018, 06:32 PM #92Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Turn on the Mueller belt
04-21-2018, 07:54 PM #935000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Looks like the new mid has just the bottom plate, not the top one. I guess that's better than none.
04-21-2018, 08:40 PM #94Scream And Fly VIP
- Jul 2013
- California
- 1,555
- 21
- 63
- 83
- 294
The last time I did it with the plasma cutter I destroyed the upper plate and saved the lower. Maybe you could get it by destroying the lower plate.
Another option is a thin cut off wheel and cut around the perimeter through the studs and all.
Either way as stuck as it sounds like it is something is going to get damaged
04-21-2018, 11:17 PM #95Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Rope tie a couple thick phone books to it and wack it with a dead blow sledge?
04-22-2018, 12:29 AM #96
Dynamite..
04-22-2018, 07:51 AM #975000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Was thinking of some sort of cutoff wheel, but will think about the sledge too. Explosives sound dangerous to me.
04-22-2018, 08:18 AM #98
You could tip the motor upside down and then spray the studs with PB blaster and let sit for a bit and spray some more, that way it may run down where it needs to get. I have not seen to many rust penetrates run up hill.
04-22-2018, 05:27 PM #995000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Upside down... that sounds interesting.
04-28-2018, 09:07 AM #100Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Any luck?
04-28-2018, 09:17 AM #1015000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Been held up with other things the last week or so. Hopefully be the end of this weekend I'll see how difficult it will be to get it upside down. My preference would be not to destroy parts if I can get away with it.
04-28-2018, 09:49 AM #102Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Hang it upside down in the stand? Soak it well at all points, let it creep in?
04-28-2018, 11:52 AM #103
04-29-2018, 07:20 AM #1045000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
One last thing I tried before getting into flipping the motor over was to heat the studs with a propane torch and then impact hammer them again...no luck.
So now I am attempting to flip the motor over… there is not nearly enough height on the stand to turn it in place, so now I’m trying to connect and lift it on a second motor lift from the stand. We’ll see how that goes.
04-29-2018, 08:27 AM #105
imo ...Flipping it upside down will yield nothing, except maybe breaking something on the power head, and maybe someone get hurt in the process.
I have removed stuck power heads using the 2 short studs in the rear, backing the nuts down and using a wedge there to get leverage and a small separation started.
Then once up a small amount ( just barely a crack 1/16")I used thin chisels to apply pressure and heat applied to the mid where the longer studs are.
I always left the motor on the boat, and had my hoist attached to the power head with a lot of lift on it, and rocked the power head hard. Between the pressure, the heat and the rocking, they all came loose. Yes, sometimes there is collateral damage, but never junked anything a dab of JB weld couldn't fill from the chisels. Thats why the wedges would likely do better than chisels.
The wedges mentioned in the postings below sound better than the chisels I used, but the process is the same and it always worked for me. I used to live in Miami and old saltwater motors was all I ever worked on. ..... Man do I love fresh water motors now !!
Oh, and if your using this in salt water..Do Not use never seize...jmo
Read through this thread, there is some good tips there.
https://www.screamandfly.com/showthr...ounted-to-boat
https://www.screamandfly.com/showthr...-to-boat/page2James H. W2F a V-King... Want 2 Fly a V-King
1994 Mercury 2.5 260 Rebuild
By Rock Steady in forum Technical DiscussionReplies: 19Last Post: 07-30-2022, 06:03 PM -
1994 Mercury Pro Max rigging
By Warrenroadie in forum Technical DiscussionReplies: 32Last Post: 02-17-2017, 04:01 AM -
Mercury Tech: 1994 2.5 200HP Mercury EFI XR
By FL_Sanger_Barefooter in forum Technical DiscussionReplies: 7Last Post: 06-26-2016, 08:20 AM -
Mercury Tech: 1994 Mercury 175 2.5 oil conversion
By Liberator225 in forum Technical DiscussionReplies: 2Last Post: 04-23-2012, 07:10 AM -
Need Some info on 1994 Mercury 200 xri
By cheapbeater in forum Technical DiscussionReplies: 3Last Post: 04-16-2009, 10:20 AM
