Results 196 to 210 of 275
Thread: Mercury 1994 2.0L 150
07-03-2018, 04:17 PM #1965000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Very puzzling. I will see what happens as more of the whole thing is assembled. Thanks for the comments.
07-03-2018, 05:21 PM #197Scream And Fly VIP
- Jul 2013
- California
- 1,555
- 21
- 63
- 83
- 294
Glastron1987 thanked for this post
07-04-2018, 08:33 AM #1985000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
07-06-2018, 10:10 AM #1995000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
As expected with this engine, the screw heads for retaining the trim sensor in the swivel bracket broke off when attempting to remove them. So the threads had to be restored. The attached E-ZLocks were used. Had to drill out an oversized hole and tap them, but it worked out with a relatively low level of pain with the bracket completely removed. The locking material on them was a bit dry so I added in some red Loctite as well. Attached is after paint touch-up. Ready to install swivel bracket now.
07-06-2018, 10:02 PM #2005000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Capnmoench liked this post
07-06-2018, 11:08 PM #2015000 RPM
- Nov 2016
- Snohomish, WA
- 203
- 15
- 9
- 16
You had better luck with your trim sender screws than me. I extracted them and tried to use a tap to clean the threads on one. Tap broke. Long story short: Ended up with a 3/8” frozen aluminum rod and jammed it into the torch heated hole. Ground it flush, drilled, tapped, painted.
Glastron1987 thanked for this postGlastron1987 liked this post
07-10-2018, 06:05 PM #2025000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
I contacted portaproducts about their composite mounts. They said they no longer sell them, but referred me to a number at Sierra. I contacted Sierra, and the technical rep knew nothing about composite mounts, just the normal rubber/metal ones.
Since I don’t have a lathe to turn some delrin ones, it looking like some solid ones will likely be the solution.
07-10-2018, 06:30 PM #2035000 RPM
- Nov 2016
- Snohomish, WA
- 203
- 15
- 9
- 16
07-10-2018, 09:10 PM #2045000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
The OEM listed part numbers are 78687 (upper) and 78249(lower) for the Long/Jet, but 77326 (upper) and 77327 (lower) for the XL/XR4/XR6. Anyone know why/what the difference is? Also, from what pictures I see the OEMs look like metal around rubber, but the Sierra (although they may not fit) appear all rubber? Makes me think the OEM would be stiffer.
Btw the boat this motor will be going will be used for (kids) tubing, skiing, barefooting and racing once in a while.
07-10-2018, 09:12 PM #205
My brother made my delrin mounts using a mill and he had to massage them to make them fit, it would of been way easier to make on a lathe though.
07-10-2018, 09:13 PM #206
I would go with OEM if u don't want solids , OEM is rubber with a metal "housing"
07-10-2018, 09:33 PM #2075000 RPM
- Nov 2016
- Snohomish, WA
- 203
- 15
- 9
- 16
Mine was the XL, so the choice was made for me. But I remember scrolling through a lot of the “wrong” parts numbers for my application on eBay and wishing I could use them. The Sierra mounts looked to be solid Delrin. They were just too fat and my adapters wouldn’t mate proper without overtorquing. I thought about chucking them up, but after deliberating, decided the stock ones lasted this long, if they last that duration again, it’s worth the $$$.
07-18-2018, 09:14 PM #2085000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Since the plates that sandwich around the the upper mounts are the same for all of the engines, why would there be a different number for the mounts for the long/jet (i.e. 78687) as opposed to the XL/XR6 (i.e. 77326)? Are the mounts difference in some way? Also it seems some suppliers don't carry the 78687 anymore and/or list the 77326 for the long/jet also.
07-19-2018, 07:49 AM #209
Edit, Whoaa apologies all. This thread showed as one page when I first looked at it and I posted that redundant nonsense.
07-20-2018, 07:16 AM #2105000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
I just bought two OEM mounts for the top and plan to use solids for the bottom. Anyone else do this? How did it work out?
1994 Mercury 2.5 260 Rebuild
By Rock Steady in forum Technical DiscussionReplies: 19Last Post: 07-30-2022, 06:03 PM -
1994 Mercury Pro Max rigging
By Warrenroadie in forum Technical DiscussionReplies: 32Last Post: 02-17-2017, 04:01 AM -
Mercury Tech: 1994 2.5 200HP Mercury EFI XR
By FL_Sanger_Barefooter in forum Technical DiscussionReplies: 7Last Post: 06-26-2016, 08:20 AM -
Mercury Tech: 1994 Mercury 175 2.5 oil conversion
By Liberator225 in forum Technical DiscussionReplies: 2Last Post: 04-23-2012, 07:10 AM -
Need Some info on 1994 Mercury 200 xri
By cheapbeater in forum Technical DiscussionReplies: 3Last Post: 04-16-2009, 10:20 AM
