Results 1 to 8 of 8
Thread: Oil injection
    Feb 2018
    Vinton Louisiana
    Oil injection
    I have a 1991 mercury black max 150 #0D038864. I recently deleted the oil injection and now its running rich. Do I need to adjust something on the carbs? all the electronics are in good shape brand new spark plugs and Gap correctly. Also I can't shut that alarm off for the oil tank just a constant beebing any suggestions? Thanks
    TN
    unhook wires to the oil module.
    are you mixing the right oil ratio?
    Feb 2018
    Vinton Louisiana
    Two wires are unhooked that came off the float inside oil tank. Is there any others? In mixing 50:1
    Did you remove the oil pump from the motor and the oil drive shaft?
    Feb 2018
    Vinton Louisiana
    Yeah I sure did oil tank is gone and I bought one of those quick silver oil pump delete stick that goes into the block.I made sure to use brand new o ring before installing. Know I notice on that stick one side is flat while the other round I just twisted till it fell in place. If I can't get that alarm to shut off I plan on reinstalling the oil tank with float and hook wires back up just where I don't have to hear that.
    TN
    unhook all wires to oil module.
    Mar 2004
    vonore tn.
    Remove oil module, remove motion sensor, just above oil pump. throw them away. premix oil between 40-1, or 50-1. If it runs rich it may be idle air valve on stbd. head. that has hose running to carb. body. it allows more air to idle circuit after motor warms up. If plugged will always run rich. Also unhook advance or idle module, on this motor it starts retarding timing advance after about 5,000 rpm. It also has a cutout in exh. port in block that will limit power output.
    Feb 2018
    Vinton Louisiana
    Ok thanks billybob. Just ran all the wires down and disconnected them, alarm is gone I mean everything haha no been at the turn of the key But it runs fine. I was wondering what that air valve was . when I got the motor it was just blowing free I thought that cant be normal so I plugged it up ill have to find where this goes and hook it up. Ill let y'all know thanks for all the tips. I got this thing on the back of a 17ft king Fisher and man that thing rolls I thought I was doing something with that johnson
  1. Replies: 0
    Last Post: 08-08-2012, 06:38 AM
  2. Replies: 7
    Last Post: 01-28-2011, 08:21 AM
  3. How can you tell Laser injection from other 2.4 injection
    By jowens in forum Technical Discussion
    Last Post: 10-10-2009, 10:29 AM
  4. Oil injection or no Oil injection (200 EFI)
    By Surfhunter in forum Technical Discussion
    Last Post: 04-14-2008, 03:57 PM
  5. Direct Injection + Conventional Injection
    By David in forum Technical Discussion
    Last Post: 02-28-2006, 06:14 PM
