Results 46 to 59 of 59
02-24-2018, 09:39 PM #46
02-25-2018, 07:44 AM #475000 RPM
- Dec 2013
- georgia
- 550
- 31
- 24
- 57
- 65
Yes I change my own oil and no I don't buy mercury 2 stroke oil. I'll continue to be happy adding to my optimax. Will you be changing your own oil on your new 4 stroke every 100hrs or will u take it too the dealer. @$17.500 for motor plus $2500 for rigging I'll pass. Lol that's $17.500 for a 175hp, $19.000 for 200hp, $20,500for 225hp and it's 475lbs dry weight I'm sure it will be close to 500lbs like a two stroke when u add oil. So again is it worth it not too me
XstreamVking liked this post
02-25-2018, 01:20 PM #48Team Member
- Lake Coochiching, Ontario
- 7,756
- 272
- 485
- 1577
- 6 Post(s)
$11550 for a 175 ProXS at Jaco's
bass pro shops used to have similar pricing, may still
02-25-2018, 04:17 PM #49
List price on the 175 Pro XS is $15,110. Compare apples to apples. Yes, the new motor is probably more expensive but the official price hasn’t been published by Mercury and we have no idea what the dealer price or street price will be.
Mark
02-25-2018, 04:43 PM #505000 RPM
- Mar 2010
- Alberta
- 363
- 15
- 33
- 29
- 231
If/when I buy one I'll change the oil in both the gear case and the power head. The dry weight to dry weight is the fair way to compare weight. How much 2 stroke oil do you have onboard with you? I like to keep the large tank at least half full and if it's not, I'm usually hauling a jug to top it up. As it's been pointed out, you need to compare list price on both motors or wholesale on both to have a true price difference. They will certainly be a lot closer in price then some of the numbers we are seeing here.
08 Checkmate 2100br 250xs
02-25-2018, 06:59 PM #515000 RPM
- Dec 2013
- georgia
- 550
- 31
- 24
- 57
- 65
List price $15k for 175hp pro xs plz post link.
I keep both 3gal oil tank full so I don't keep oil onboard
02-25-2018, 07:17 PM #52
The omc sterndrives were a pos but to be fair most failed from the wrong type of oil, they had spring clutches and had to have thin oil and allot of people put heavy viscosity 90w gear oil in and they would go into both fwd/rev at the same time , boom..., the outboard elect hyd was fine the wire insulation from the 60s rotted and that was the main problem.. no power was fwd, power on 1 solenoid was neutral power on 2 solenoids was rev as i remember.. dave
02-25-2018, 07:41 PM #53
02-25-2018, 09:53 PM #546000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
02-25-2018, 10:02 PM #55Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
8 hrs a day
7 days
4 years
Good innings
02-26-2018, 06:43 AM #56
02-26-2018, 07:40 AM #575000 RPM
- Mar 2005
- Savannah,Ga.
- 251
- 14
- 185
- 58
Just ordered a new 150 ProXS four stroke , got a sweet-heart deal from a local dealer. Only problem is I cant get it until May! Replacing my 150 60 degree Johnson on my 1820 Actioncraft flats boat. Sure will miss the sound,smell and the punch, but am hoping for much more range.
WavetoWave liked this post
02-26-2018, 08:24 AM #58
In the pics on the other thread it shows what looks like the electric shift actuator in the mid section spacer...below the water line , is elect shift only avail in 25in motors ? doesnt appear to be enough room without the spacer in there..
02-28-2018, 06:09 PM #59
wtsjr66 liked this post
merc 150 4 stoke oil change spout size- what diameter hose to use?
By CircleHook in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 2Last Post: 08-16-2017, 12:14 PM -
I Am Looking Opinions On Putting 2 300X Motors On My Cougar 22MTR!!
By Hydrogasm in forum General Boating DiscussionReplies: 66Last Post: 12-21-2016, 06:36 PM -
Opinions on 300X Motors- 2001 VS 2002 and Newer Models!!
By Hydrogasm in forum General Boating DiscussionReplies: 7Last Post: 11-15-2016, 09:25 AM -
Opinions on the new Evinrude G2 Motors
By Carter Powell in forum General Boating DiscussionReplies: 7Last Post: 01-03-2015, 07:51 AM -
Allison 2002xb... swap 2.5L for which 4 stoke... opinions please
By soggybear in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 75Last Post: 04-03-2009, 09:52 PM
