Results 1 to 4 of 4
Thread: 2.5 Drag motors
    Aug 2006
    Ohio
    2.5 Drag motors
    Can anyone give me opinions on pros and cons of a drag motor vs a 280 or 260?
    shreveport,la
    For most uses I'd take the 280 over the Drag. 280 has better bottom end and will still turn plenty of rpm to satisfy 98% of boaters. What is your intended use
    Erik Kiser
    Aug 2006
    Ohio
    Recreational boating. Looking at a 22DCB with twin drag motors. Don’t know much about outboards. Have heard the drag motors are not reliable, short life span, finicky,etc. owner says he has never had any problems. Also no record of hours.
    shreveport,la
    They use the exact same parts so given the same rpm ranges the lifespan will be the same. The Drag might be single ring pistons which will just mean more ring changes. If you're looking to buy the rig I'd run a leakdown test. The Drag engine is no Optimax but I don't agree with them being inherently unreliable or finicky
    Erik Kiser
  5. Thanks convincor thanked for this post
  1. Last 2 of Jon Wright's drag motors
    By Spectre Powerboats in forum Outboard Engines
    Last Post: 10-19-2016, 06:04 AM
  2. '97 Talon22 w/Twin Merc SVS Drag Motors
    By Two Steppin in forum Hulls larger than 20'
    Last Post: 03-12-2016, 08:13 PM
  3. 25 talon tripple 300 drag motors
    By PARKER RABE in forum General Boating Discussion
    Last Post: 03-05-2016, 05:24 PM
  4. new 20 ft mirage, twin drag motors!!!
    Last Post: 03-14-2015, 08:11 AM
  5. why do white drag motors sound different?
    By mike bryan in forum Technical Discussion
    Last Post: 11-07-2005, 06:11 PM
