Page 11 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 151 to 165 of 241
  1. #151
    Aug 2012
    beaumont, tx
    another question.....ive been told time and time again that the a48 curve is "safer" for boat riding over the a6
    using the brucato software to look at each map....i dont see the difference besides fuel psi compensation
    maybe one of u merc guys can explain how its "safer"
  2. Likes Noah Burns liked this post
  3. #152
    May 2008
    S.Tpa
    I couldn't let it die without at least sharing the remains of #2
    If Dave follows his norm - he should have it about right by # 4
    I have gone to find myself , If I return before I get back - Keep me here
  4. Likes Capt.Insane-o, texasvector liked this post
  5. #153
    Aug 2012
    beaumont, tx
    guess we decided to end this conversation
  6. #154
    Nov 2013
    Oak Hill Fl.
    Well come on down to the river in 2 weeks and watch #3 in action.
    River Ranch run just north of Camp Mack bridge under the big oak trees.
    Will have a keg and a grill going. Should be a good time to watch it melt down....................
  7. Likes Tom Foley liked this post
  8. #155
    Shreveport, La.
    A-6 has to be set up w/lap top by someone with knowledge and experience doing it. If the fuel curve is rich enough then it should be safe but seems kind of wasted on a lake boat. I would run an A-48 set rich enough to make the motor live.
  9. #156
    Aug 2012
    beaumont, tx
    Quote Originally Posted by Da Bull View Post
    thats another one of my questions bull......im using brucato software and have both a6 & a48 to look at.....on the laptop the 2 curves seem to have the same graph other than fuel psi comp. (could just be a brucato thing) but i dont see the differnce.
    ive ran a A6 on my lake boat and it did wake it up but toasted 1 after 30 hrs ( not sure if it was fuel map related)
    i can and did add fuel to the A6 in certain places but was asking if it was in correct spot and enough added to be safe while cruising
  10. #157
    It's been a few beers and a few years but Tony's 6 curve has the "fix" in it if I remember right and it's up to you to adjust from there. The original factory a6 box was meant to run through the rpm range at full throttle on a light boat with a small prop. Not to have a 32 on and linger around with the cruise control on.
    They came on 2.5 drag race motors, not 2.5 sight seeing motors.
  11. Likes texasvector liked this post
  12. #158
    Aug 2012
    beaumont, tx
    cappy i understand what the a6 was intended for.
    i didn't know brucato had "the fix" in it already.... would make sense why the a6 and a48 are looking identical
    goal was to have a 56lb boat riding curve.....no matter what i called it.....cause i have seen the higher psi help
    certain someone in FL is running big props with modded a6 i believe.....i was just looking for someone to teach me where and why
  13. #159
    Nov 2013
    Oak Hill Fl.
    Well I finally got it to run wide open throttle and not melt down.
    WH-15 .106 mains. 8 PSI fuel pressure stock needle and seats.
    Goes full rich at wide open EGTs drop off from 1150 to 1030 at full open. Stalls at 7600 RPM 93 MPH 28p prop.
    Using stock cut heads for now till the billet pucks come in. 110 PSI cranking pressure.
    Can run miles and miles wide open now no problem. will lean on it from here when I get the good heads back on it.
    See you all at The Kissimmee river this weekend...........................................
  14. Likes 89LASER, nitro_rat liked this post
  15. #160
    Mar 2010
    houston, tx
    Quote Originally Posted by texasvector View Post
    Are you running 16amp charging? Some of the guys I know went to a 39psi for boat riding and switch to a 56 for racing and either run an adjustable regulator or switch them out due to the fact that they found the 39psi system draws less amps running the pump on long runs to not wear the battery down too much. Depending on your battery size options this might be something to ponder.
  16. Thanks texasvector thanked for this post
  17. #161
    Mar 2010
    houston, tx
    Quote Originally Posted by dwilfong View Post
    watch your needles and seats, 8 psi might start to cause problems, I can’t run mine that high it will float them and flood the motor.
  18. Thanks texasvector thanked for this post
  19. #162
    Aug 2012
    beaumont, tx
    16 amp..... adjustable reg
    I've ran the 56 for a season with no issues except have to charge before every time out. ....
  20. Likes 90 5.0 liked this post
  21. #163
    Mar 2010
    houston, tx
    Big batteries? That makes a big difference too, and length of runs.
    I’ve seen before for boat rides with 56, guys taking the smaller 12v for 24v trim and rewiring for 12v parallel for extra compacity for boat rides and just not having 24v trim(who uses a trim computer for boat riding anyway lol).
    Glad it’s working for you, I’d rather have the 56 too and deal with the bigger battery
  22. #164
    Aug 2012
    beaumont, tx
    yes...big battery(thats my balance).....this is just a river boat......no racing......just the more than occasional WOT run for a mile or so
  23. Likes 90 5.0 liked this post
  24. #165
    Congratulations you built yourself an ok running 200 or a lazy ass 225 pro max.
  25. Likes 90 5.0, 1BadAction liked this post
  1. 20' Action Marine restoration/resurrection.
    By Hot Shot Merc in forum General Boating Discussion
    Last Post: 08-12-2023, 02:11 PM
  2. Cosworth 275 Resurrection
    By promax150 in forum Technical Discussion
    Last Post: 07-16-2015, 08:33 AM
  3. Aquabuff-Rallysport Resurrection
    By Checkmate2.5 in forum Detailing and Care
    Last Post: 03-26-2008, 07:21 AM
  4. 2.4 Resurrection
    By Surface Scratcher in forum Technical Discussion
    Last Post: 02-25-2008, 07:49 PM
