Results 1 to 3 of 3
02-12-2018, 04:49 PM #1
3.0 liter Lower unit design change?
Did early 3.0 gear cases come with only 5 holes in the water pickups? and a larger cavitation plate?
Does anyone know when they changed to the current style?
02-13-2018, 04:03 PM #25000 RPM
- Mar 2004
- vonore tn.
- 225
- 21
- 28
I think the very early, torque masters, came with just 5 holes. but it is very possible it has 8 holes, & the top 3 holes are bondoed, to run higher on transom. The current style is the GEN 2. it is completely different. merc. has upgraded 3.0 l/u,s many times, even including verado gearcase, with 7 degree shift shaft offset. they went gen 2 in 2016. on xs motors.
02-14-2018, 08:59 AM #36000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
I'm told the gen 2 has a much bigger pinion gear
Mercury Tech: 2.4, 2.5 liter fishing lower unit into a 3.0 torque master lower unit
By cactusth in forum Technical DiscussionReplies: 3Last Post: 08-12-2011, 09:51 PM -
Lower Unit Change
By Blazer95 in forum Technical DiscussionReplies: 0Last Post: 06-19-2010, 11:11 AM -
OMC lower unit change?
By drjerry1st in forum Technical DiscussionReplies: 5Last Post: 04-19-2010, 12:28 PM
