Results 1 to 4 of 4
Thread: 2.4 200 reed question
02-12-2018, 09:10 AM #1
Hey fellow scream and flyers! I just acquired a 2.4 200 and it has 5 pedal horizontal reeds with wh22 carbs. What could I expect if I swap to a 4 pedal cage and reed? Thanks for any info
02-12-2018, 11:46 AM #2Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
The 4 petal cage can flow a little more than the 5,but breaks its metal leafs much more often...so if you go to the 4 petal cages you should go to composite reeds,also,by going to the 4 petal cage there's plenty of room to use the .125 thick crankcase stuffers we make,the 5 petals will only allow the .065 stuffer.We have the reeds and stuffers in stock,Chris
David - WI, LetsBoat liked this post
02-12-2018, 12:55 PM #3
Thanks for Info Chris, I believe the rubber on the 4 pedal cages r cracking ,what would it cost to get cages worked, set your 4 pedal reeds,intake spacer and stuffer? Thanks
02-12-2018, 01:44 PM #4
On a stock motor turning normal rpm's I doubt you will see any differance. Mike
Cheaters never Win !!!
reed question
By rickriddle in forum Technical DiscussionReplies: 6Last Post: 05-14-2006, 08:33 PM -
Reed Question
By the witchdoctor in forum Technical DiscussionReplies: 5Last Post: 03-01-2006, 07:43 PM -
reed question for Jay
By Bones in forum Technical DiscussionReplies: 3Last Post: 01-02-2004, 06:45 PM -
Reed question
By AwesomeBullet in forum Technical DiscussionReplies: 3Last Post: 01-01-2004, 11:52 PM -
Reed Question ?
By TEXAS20225 in forum Technical DiscussionReplies: 3Last Post: 06-16-2003, 07:41 AM
