Results 16 to 30 of 62
Thread: Boyesen to CCMS Reeds Comparison
02-10-2018, 06:49 PM #16
Apart from everyone who says how good ccms reeds are there is another big factor PRICE. he cant be beaten on price.
this allows for a spare set to be kept just incase.
Boyesen dont have the reputation they used to have, and that was because they had a monopoly on the aftermarket reeds and sponsored
lots of the bike boys.
Boyesen would probably be 3rd on my list of reeds. chris carson reeds 1st
02-10-2018, 07:17 PM #17
CCMS is the best way to go. great reed and even better service.
phillnjack, litespeed liked this post
02-12-2018, 09:20 AM #185000 RPM
- Aug 2008
- ILLINOIS
- 183
- 13
Thank you
have them on order!!
phillnjack liked this post
02-15-2018, 07:09 PM #195000 RPM
- Jun 2017
- Connecticut
- 263
- 38
- 19
- 33
- 21
I wrote Mercury again explaining that I was not happy with the first answer and actually got back a very good response from someone who knew what they were talking about.
They explained that stress fatigue was highly variant due to different user cycles (engine load vs RPM). That the reeds bent in different ways sometimes twisting under certain load to RPM fluctuations that could greatly affect fatigue life. Because of high variations in stress do to different reed motions they didn't have a good analytical model for reed life.
He did however say that fiberglass reeds should be inspected every 100 hours and replaced if chipped, and steel reeds should be replaced every 300 hours regardless of condition.
Make sense as the composites are less tough and could fracture from being damaged but should basically have an infinite fatigue life if undamaged.
Mark75H thanked for this postWillySteve, Mark75H liked this post
02-15-2018, 09:27 PM #20Member
- Jul 2017
- upstate ny
- 47
- 7
For what its worth...I put the cc reeds in my 9.9/15 that I did alot of internal work using ideas from here. It runs wot at 7400 with a 10p 4 blade. I use the motor 200 hours per season. The cc reeds lasted 1 season before the ends chipped. Last year I put in the Boyessens. I just checked them and they are pristine. The reed plate is flat on that motor and I feel the 2 stage reeds land on the plate softer than the cc reeds. Maybe the plate needs to be rubber coated..jmho..
I feel reed choice might be motor specific..So I feel the above response from Mercury is spot on.
02-19-2018, 12:54 PM #21
rudderless...
Did you leave the stops off when using cc reeds ? .... if yes, there is your answer. ccms recommends to keep the stops and the shims I believe .
I agree 200 hours is not very long for reeds to be chipping at the edges, but at the rpm you are running did you buy race reeds or just normal or sport reeds ?
02-19-2018, 09:32 PM #22Member
- Jul 2017
- upstate ny
- 47
- 7
There is a story about that..I got the '76 motor in a box 4 years ago. The so called reed stop screws got loose and the stop and reeds were smacking into the crank throw. A piece of reed broke off very early in its life. Was in a box for years.
So...yes it was as supposed to be. Maybe some behind the liner work and such that I got from here. And they were the race reeds..all I could find were the race reeds on ebay at the time..didn't know any better at the time. They wore at the very end. I don't run it anywhere near wot though. The current ones are looking good so far. I think the center, smaller reed has some cushion landing on top of the larger reed. And maybe the large reed doesn't lift as far off the plate? Maybe reed choice might partly be a function of motor design...Last edited by rudderless; 02-19-2018 at 09:37 PM.
02-21-2018, 08:44 AM #23
were they direct from chris carson or some other seller ?
did you also put back the shims on the reed stops ? so they fit as in" reed-shim-stop".. and I take it your not using stops with the boyesen reeds ?
and just saying , but race reeds would not hold up as long as recreational or sport reeds, they each do a different job and will last differently.
02-21-2018, 09:02 AM #24Supporting Vendor
- 11,838
- 163
- 11
- 795
Try the TDR (Tony Doukas ) reeds , I can use anyone's reeds on my many rebuilds haven't had a failure or complaint yet in 20 years of building Mercurys !!!
From 11,000 rpm all out race motors to 5,500 recreational they can't be beat !!
Jay @ JSRE
832 597 3603Jay @ JSRE
Krazymaan liked this post
02-21-2018, 04:16 PM #25Member
- Jul 2017
- upstate ny
- 47
- 7
Yes..the shim and guide were installed as per conversation with a cc rep on the phone..didn't get a name.
I did google TDR reeds as per this forum and it seemed they were not in business anymore so I went with cc reeds. Like I said they were on ebay and I bought them without doing my homework first..Sport would last longer
02-21-2018, 04:46 PM #26Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
I spoke with TDR two weeks ago. They're answering
02-25-2018, 07:39 PM #27Supporting Vendor
- 11,838
- 163
- 11
- 795
I'll assure you TDR is still alive and well , Tony has been building 2 cycle reed valves for over 35 years , NO ONE knows more about 2 cycle reed application than Tony ..
JayJay @ JSRE
03-01-2018, 08:59 AM #28
Like Jay says, TDR reeds are great.
03-01-2018, 01:27 PM #29
I've been using the tdr reeds on coated sport jet cages to great success and longevity. I've used Chris's reeds in a lot of customer motors and a couple of my own with no complaints. Boysen, never again.
03-02-2018, 01:47 PM #306000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
Captain75 thanked for this post
Which reeds (CCM, Boyesen, or TDR)?
By modvp in forum Technical DiscussionReplies: 60Last Post: 06-26-2017, 01:36 PM -
reeds...Boyesen vs CCM some help please!
By Valero2.5 in forum Technical DiscussionReplies: 22Last Post: 07-02-2014, 09:18 AM -
BOYESEN REEDS VS LAND & SEA REEDS
By MrCougar in forum Technical DiscussionReplies: 1Last Post: 05-14-2001, 07:08 AM
