Results 16 to 18 of 18
Thread: Mercury Oiler Gear
02-12-2018, 06:24 AM #16
I spun the drive gear out of a 2.4 on my twin engine Seebold making a rough water run back down the James River. I was on the wheel but I had Captain Morgan on the sticks. That may have had something to do with it....
18 Talon/2.4 carb SOLD
26 Deck Boat/250 Merc
Glastron1987 thanked for this post
02-12-2018, 10:51 AM #17
Glastron1987 thanked for this postGlastron1987 liked this post
02-14-2018, 10:21 AM #185000 RPM
- Jun 2017
- Connecticut
- 263
- 38
- 19
- 33
- 21
Different gear designs have different factors such as angles they can interact, loads they can withstand, and how much the gear teeth flanks roll or slide.
Helical gears in your car transmissions and spiral bevels in your differentials have very little sliding between them and are mostly rolling and there fore have less wear and heat generation.
The worm gear used on oil injection system has some of the highest sliding contact but they needed a worm gear unless they added a belt or worked off the flywheel or something. Mercury was probably expecting high wear at this interface and opted for wear particles that would not harm the rest of the engine vs metalic chips. Also with lubrication in a two stroke crankcase being inferior to a four stroke with an oil pump, nylon is a little more self lubricating and forgiving than metals.
They realized the design was not as robust as it could be after 2 decades and they switched to electric oiling pumps on both the EFIs and DFIs.
2.5 200 hp block stuffing for oiler gear
By laser380 in forum Technical DiscussionReplies: 12Last Post: 04-25-2012, 10:17 PM -
Oiler Gear Aluminum Replacement
By Scott in MN in forum Technical DiscussionReplies: 4Last Post: 03-26-2011, 04:44 PM -
oiler gear
By Deacon in forum Technical DiscussionReplies: 7Last Post: 09-30-2009, 11:46 PM -
oiler gear check
By Specialized P4-12 in forum Technical DiscussionReplies: 9Last Post: 01-16-2008, 11:10 AM -
Should oiler gear be loose at all?
By WATERWINGS in forum Technical DiscussionReplies: 5Last Post: 03-27-2003, 12:38 PM
