Results 1 to 15 of 31
Thread: stringers
02-07-2018, 10:40 AM #1Junior Member
- Feb 2018
- Tappahannock Virginia
- 15
stringers
I need advice on stringer repair on my 1987 Villain III.
I found a soft spot in the floor while removing engine in order to replace leaky shift cable tube.
Approx. 6 ft. forward i found good wood. Can this stringer be spiced?
02-07-2018, 12:41 PM #2Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
You will be putting off the inevitable. (complete replacement) But you can splice the stringers using a scarf joint of about 4'' long with glass between and using a couple of layers of biaxial glass over it.
Noah Burns liked this post
02-07-2018, 05:43 PM #3Junior Member
- Feb 2018
- 15
Why say inevitable? will the stringers continue to rot?
Is there anything to stop rot from progressing forward?
02-07-2018, 07:34 PM #45000 RPM
- Mar 2015
- DFW
- 665
- 16
- 42
- 366
- 232
Have you ever known wood to just stop rotting? He is right, if it has started, you might as well do the job right and spend just a little more time and do it all. Think about it, you're going to have to cut and grind some of it out of there to replace, why not just finish the job and have total peace of mind?
02-07-2018, 08:05 PM #5Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
Un sealed wood has a finite life span. It's duration is determined by it's exposure to moisture, either directly or from the air. Totally sealing it will prolong it's life, but once bacteria and mold get a foothold it is a matter of time sealed or not. It is not visible, but it's there. Might buy enough time with the replacement of the worst of it, to give you several more years.
02-09-2018, 08:18 AM #6Junior Member
- Feb 2018
- 15
Any ideas on what wood was used from factory? What wood should be used for replacement/repair? The stringers don't look like anything regular pine 1x10.
02-09-2018, 10:53 AM #7Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Guts it all, clean slate. Marine ply , Baltic of you want to get extra fancy, mahogany is another with more surface prep. Pails of resin, epoxy too, yards of cloth, mat etc. Transom, stringer, bulks , add strength and performance. Work around the good dry foam , most folks take it all out. Add strength to the running surface of the hull. Never look back
02-09-2018, 02:58 PM #8Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
02-09-2018, 07:08 PM #9Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
If you get to a second time around you'll kick yourself for doing it twice. I'd kick myself that I know.
02-10-2018, 09:04 AM #10Junior Member
- Feb 2018
- 15
" guts it all" would be the action if any core rot was found. Core, bulks, transom all solid.
02-10-2018, 09:35 AM #11Junior Member
- Feb 2018
- 15
i removed stringer up to good wood. I am gonna open up other side to see if any rot under floor. What i see on other side will determine my decision to patch or total replacement.
02-10-2018, 09:40 AM #12Junior Member
- Feb 2018
- 15
Does anybody know what type of foam would have been used in production? None of the foam was wet.
02-10-2018, 09:50 AM #13Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
I had to search a pic of your boat, from what I found it is a classic great looking boat. Well worth the effort, glad for you it's just a small repair. How's the power?
02-10-2018, 10:20 AM #14Junior Member
- Feb 2018
- 15
FMP liked this post
02-10-2018, 10:23 AM #15Junior Member
- Feb 2018
- 15
Well she did get a pair of SS headers this time.
Original gel, interior.
FMP liked this post
Where should I put the stringers?
By loop in forum Fiberglass and Composites DiscussionReplies: 2Last Post: 04-29-2012, 10:50 AM -
HELP PLEASE!! LASER 380 Stringers
By Lost-in-MX in forum Fiberglass and Composites DiscussionReplies: 16Last Post: 05-04-2010, 09:50 AM -
How to cap stringers???
By Riverman in forum Fiberglass and Composites DiscussionReplies: 10Last Post: 10-26-2005, 08:45 PM -
stringers
By IG-NITION in forum Fiberglass and Composites DiscussionReplies: 3Last Post: 11-01-2004, 10:42 AM -
New Stringers
By Dargo in forum Fiberglass and Composites DiscussionReplies: 26Last Post: 12-10-2003, 08:38 AM
