Results 1 to 2 of 2
    Feb 2018
    Complete EFI / CDI System from running 2.5L 2000 200 EFI 2 Stroke For Sale
    Up for sale is above mentioned Factory EFI System, Complete with all harnesses, computers, sensors, ECM, CDI's, Flywheel, intakes, manifold, fuel rail, injectors, stator, linkages, brackets, vapor canister/fuel pump and all hardware. Came off well running 2000 200 EFI Mercury 2 stroke. Went with a newer higher power outboard, so i no longer need this stuff. Below is the list of the major components, but comes with all lines, wires, solenoids and hardware which probably arent listed in below parts list.
    Feel free to make offers guys, id rather sell it in one chunck vs piecing over over ebay for months.
    part number alt part number description QTY
    84-858425T1 HARNESS ASSEMBLY Power
    8571621 PLATE CDM Mounting
    827509T7 CDM MODULE ASSEMBLY 6
    84-857163T1 HARNESS ASSEMBLY CDM
    84-857165T1 HARNESS ASSEMBLY Engine Wiring
    84-858702T1 CABLE ASSEMBLY Adaptor
    883072T2 REGULATOR Voltage 2
    828151A1 RELAY ASSEMBLY 2
    84-819514A11 HARNESS ASSEMBLY Trim
    89-817109A2 SOLENOID ASSEMBLY
    18896A1 COVER KIT - FLYWHEEL
    271-859238T4 FLYWHEEL ASSEMBLY
    398-858404T3 STATOR ASSEMBLY
    96455A18 TRIGGER ASSEMBLY
    824003A30 ECU Engine Control Unit
    13202A5 MODULE ASSEMBLY - WATER IN FUEL
    14817A31 MANAGEMENT ASSEMBLY Fuel
    8276922 COVER
    84-15443 HARNESS KIT fuel injector
    827699T2 FUEL RAIL
    18715T INJECTOR ASSEMBLY 6
    8276933 THROTTLE BODY
    13221A1 SENSOR ASSEMBLY Temperature
    148512 THROTTLE POSITION SENSOR
    14817A31 MANAGEMENT ASSEMBLY Fuel Vapor
    857169T2 CONTROLLER - IGNITION
    826800A9 CONTROLLER ASSEMBLY Detonation
    13536A14 SENSOR ASSEMBLY Temperature (PORT)
    815699T PUMP ASSEMBLY Oil
    994436 37-825068 RESERVOIR - OIL
ID:	398907Click image for larger version.
ID:	398908Click image for larger version.
ID:	398909Click image for larger version.
ID:	398910Click image for larger version.
ID:	398911Click image for larger version.
ID:	398912Click image for larger version.
ID:	398913Click image for larger version.
    Mar 2004
    vonore tn.
    You need to list this on MISC. PARTS & ACC. Hardly anyone looks here.
  1. Complete EFI / CDI System from running 2.5L 2000 200 EFI 2 Stroke For Sale
    By ibhurln in forum Misc. Parts and Accessories
    Last Post: 07-14-2018, 07:09 AM
  2. 2000 300 promax for sale complete or parts
    By BigKiddd in forum Outboard Engines
    Last Post: 08-10-2016, 08:02 PM
