Up for sale is above mentioned Factory EFI System, Complete with all harnesses, computers, sensors, ECM, CDI's, Flywheel, intakes, manifold, fuel rail, injectors, stator, linkages, brackets, vapor canister/fuel pump and all hardware. Came off well running 2000 200 EFI Mercury 2 stroke. Went with a newer higher power outboard, so i no longer need this stuff. Below is the list of the major components, but comes with all lines, wires, solenoids and hardware which probably arent listed in below parts list.
Feel free to make offers guys, id rather sell it in one chunck vs piecing over over ebay for months.
part number alt part number description QTY
84-858425T1 HARNESS ASSEMBLY Power
8571621 PLATE CDM Mounting
827509T7 CDM MODULE ASSEMBLY 6
84-857163T1 HARNESS ASSEMBLY CDM
84-857165T1 HARNESS ASSEMBLY Engine Wiring
84-858702T1 CABLE ASSEMBLY Adaptor
883072T2 REGULATOR Voltage 2
828151A1 RELAY ASSEMBLY 2
84-819514A11 HARNESS ASSEMBLY Trim
89-817109A2 SOLENOID ASSEMBLY
18896A1 COVER KIT - FLYWHEEL
271-859238T4 FLYWHEEL ASSEMBLY
398-858404T3 STATOR ASSEMBLY
96455A18 TRIGGER ASSEMBLY
824003A30 ECU Engine Control Unit
13202A5 MODULE ASSEMBLY - WATER IN FUEL
14817A31 MANAGEMENT ASSEMBLY Fuel
8276922 COVER
84-15443 HARNESS KIT fuel injector
827699T2 FUEL RAIL
18715T INJECTOR ASSEMBLY 6
8276933 THROTTLE BODY
13221A1 SENSOR ASSEMBLY Temperature
148512 THROTTLE POSITION SENSOR
14817A31 MANAGEMENT ASSEMBLY Fuel Vapor
857169T2 CONTROLLER - IGNITION
826800A9 CONTROLLER ASSEMBLY Detonation
13536A14 SENSOR ASSEMBLY Temperature (PORT)
815699T PUMP ASSEMBLY Oil
994436 37-825068 RESERVOIR - OIL
ID:	398882Click image for larger version.
ID:	398881Click image for larger version.
ID:	398883Click image for larger version.
ID:	398884Click image for larger version.
ID:	398885Click image for larger version.
ID:	398886Click image for larger version.
ID:	398887Click image for larger version.
