Results 1 to 11 of 11
Thread: speed up trim
02-05-2018, 06:35 PM #1Junior Member
- Oct 2014
- Arlington, Texas
- 12
speed up trim
need to get my merc drag outboard to trim up faster.
02-05-2018, 06:40 PM #2Scream And Fly VIP
- Jul 2013
- California
- 1,555
- 21
- 63
- 83
- 294
Use an I/O pump or 24 volts to pump motor or both.
new thanked for this postWillySteve liked this post
02-05-2018, 06:52 PM #35000 RPM
- Mar 2015
- DFW
- 665
- 16
- 42
- 366
- 232
when using the I/O pump, is the wiring and plumbing all the same?
STV Pro Comp Ski| 200 Merc
02-05-2018, 06:56 PM #4Scream And Fly VIP
- Jul 2013
- California
- 1,555
- 21
- 63
- 83
- 294
Wiring is the same. Might have to do some fitting changes for the hoses.
If you have a Mercury trim pump in the boat now and going to a Mercruiser trim pump you should be able to swap out fittings.
02-05-2018, 10:56 PM #5
Post pic of the pump, you might already have a mercruiser style pump and just need to wire for 24v
02-07-2018, 01:28 AM #6
Might be wise to see if the "up" spring in the bypass is sacked out and hemorrhaging . Simple adjustment does wonders . If that's not fast enough , the channels are pretty small in the valve body . Don't get to drill happy to fast .... you'll be threadin and jettin .
02-08-2018, 12:43 PM #7
Run the trim on 24 volts with an IO pump. It will be very fast then.
02-11-2018, 04:07 PM #8Junior Member
- Oct 2014
- Arlington, Texas
- 12
Thanks for the info. Do you know where I might obtain a diagram for 24 volt wiring and is it OK top run my 12 volt motor at 24 volts?
02-12-2018, 05:38 AM #9
02-12-2018, 08:02 AM #10
Onetime liked this post
02-12-2018, 10:57 AM #11
I ran dual blinker type trim on the wheel. Left side trim was 24 up and 12 down, right side had 12 up and 12 down.
Trim speed and jack plate speed
By Krazymaan in forum General Boating DiscussionReplies: 9Last Post: 06-04-2017, 06:40 AM -
evinrude trim speed
By N Wolf in forum Technical DiscussionReplies: 8Last Post: 06-17-2014, 08:43 PM -
Power Trim SPEED
By MidnightCarving in forum Technical DiscussionReplies: 7Last Post: 01-12-2012, 07:56 PM -
Slowing trim speed
By RBT in forum Technical DiscussionReplies: 15Last Post: 10-01-2008, 07:16 AM -
Merc Trim Speed (help)
By nitemaher in forum Technical DiscussionReplies: 6Last Post: 03-21-2002, 01:47 AM
