Results 1 to 5 of 5
Thread: Trigger
02-05-2018, 06:10 PM #15000 RPM
- Aug 2006
- GA
- 855
- 25
- 35
- 71
Trigger
V6 Merc 2.5 200 Carb. The 6 wire was snipped into & the bands are gone. There all the same Color. Which 3 go to the front switch box & 3 to the back ??
02-06-2018, 03:06 AM #2
First thing that comes to mind is just connect them to the switch boxes with purple up top, white in the middle en brown on the lower terminal. Then indicate TDC of each cylinder on the flywheel, ground your plug wires and use a timing light to differentiate for each color whether they are connected right (between 1&2, 3&4, 5&6) or need to be switched around.
02-06-2018, 09:28 AM #3New Member
- Feb 2018
- live oak fl
I'm not sure if this will help, but, I just looked at the trigger we took off our 91 200. The wires that should have the yellow band are slightly longer than the ones that have the black band :-)
02-06-2018, 10:08 AM #45000 RPM
- Mar 2004
- vonore tn.
- 225
- 21
- 28
on all older merc,s with dual switch boxes CDI makes primary wire kits. I would order them for reliability. if not install wires from cyl. 1,3,&5 on 1 switch box. & wires to 2,4,&6 on other switch box. trigger wires only are 3 colors, just 1 of each color to each switch box. if you have doubt about trigger buy a new one. they,re cheap compared to other parts. example $90.00 for 14 inch long hose & 2 otiker clamps for hose between air comp. & fuel rails, on opti.
02-06-2018, 11:30 AM #5
I would not even mess with it, buy a new one.
Bad Trigger??
By eagleoffshore in forum Technical DiscussionReplies: 0Last Post: 08-12-2008, 07:35 PM -
bad trigger?
By allyfreak2 in forum Technical DiscussionReplies: 11Last Post: 10-01-2007, 03:31 PM -
Using the right trigger
By nightfisher in forum Technical DiscussionReplies: 2Last Post: 06-15-2007, 11:38 AM
