Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 62
Thread: Purdy ole truck
  1. #46
    May 2014
    Livingston, Louisiana
    It’s definitely a little overkill for this motor, but the system does a really good job cutting down the pulse width to keep mixture right.
  2. Likes CDave liked this post
  3. #47
    May 2014
    Purdy $4000 brake job on a C63 bi-turbo
    .Click image for larger version.
ID:	439138Click image for larger version.
  4. #48
    Nov 2018
    New Baltimore Michigan
    Attachment 435332Attachment 435333Attachment 435334
    Definitely no where near purdy, but unique anyway. It’s an Avanti II, the original Avanti was made by Studabacker. This one is a 1970 model and is made of a combination of Ford, Gm, and Chrysler parts by the Avanti motor company. This one has a Gm 350 in it, I’m gonna be removing the Quadra-Jet and installing throttle body fuel injection and installing electronic ignition. The little car is excellent condition, just ain’t never seen one like it before.
    The original Avanti is considered one of the best looking cars ever built in America. OPinions vary.
  5. Likes FORBESAUTO liked this post
  6. #49
    Nov 2001
    Lake Charles, Louisiana
    Was the 4K for a brake kit?
    93 STV Mod VP/MERC 2.5 200
    Proverbs 4:18-20
    -- John F. Kennedy 1962
  7. #50
    May 2014
    Unfortunately not, that was just oem front and rear rotors, pads, and sensors. It uses carbon ceramic brakes. High dollar mess
  8. #51
    Nov 2001
    I thought carbon ceramic rotors were black?
    Proverbs 4:18-20
  9. #52
    May 2014
    Your right, not 100% sure what these things are made of. Some kind of composite or something, or at least hope its some time of space age material with price of them. I just remembered from years back at mercedes school when one of the amg cars came out it had some type of ceramic rotors, so when i saw the price of these babies just figured thats what it was. The center hub is not magnetic, may just be aluminum. They are fairly light for the size of them.
  10. Likes CDave liked this post
  11. #53
    Nov 2001
    I'm just glad it isn't my car. I just ordered a new distributor for my 95 K1500, 55.00.
    I imagine one coil on that MB would be more that 55.00.
    Proverbs 4:18-20
  12. Likes Forkin' Crazy liked this post
  13. #54
    NE Louisiana
    4$K for parts not including labor? Not happening here!!!
  14. #55
    May 2014
ID:	448932Click image for larger version.
    Installed a MSD Atomic EFI system on a 302 in an 65 Mustang. Have to say I think I like this system better than the FAST. The ecu is located on the throttle body assembly and has a seperate driver module that controls the fuel pump via pulse width modulation depending on data from a fuel rail pressure sensor, eliminating the need for a fuel pressure regulator. The driver module also has outputs for two cooling fans programmable on/off temps using the the handheld controller that also plugs into a port located on the driver module. System real easy to install, and easy to set up. Seemed to also adjust to motor much more quickly. Has ability to have timing control when using msd ignition module, nitrous input to richen fuel mixture, works with both pulling and pushing blower/turbos.
  15. Likes CDave liked this post
  16. #56
    Nov 2001
    Looks like a solid unit. Is the harness long enough to locate the ECU inside the car?
    Proverbs 4:18-20
  17. #57
    May 2014
    The ecu is actually the unit with the MSD logo on it on the side of the injection/ throttle body unit. But yes, the harness is long enough to put the power driver module inside vehicle. I chose to put it on the fender apron because the wiring for the wideband o2 goes to it and wires for fan(s) from it, that location had it centrally located without having to add extensions to either. I originally was thinking of putting it inside, but the o2 sensor harness limited me to where I could put it.
  18. Likes CDave liked this post
  19. #58
    Oct 2018
    Tennessee
    Looks great man
    (Rip. Whiteally02) -dad
  20. #59
    What kind of fuel mileage increase (if any) do you anticipate?
    May 2014
    Really don’t know, both customers made the switch mainly for drivability improvements. Doubt either one even know what their fuel mileage is. I would think it would definitely be better under normal driving just because of it being able to keep the fuel mixture correct at different conditions better than the carb could. Not so sure about under hard running situations where its possible to lose mileage but pick a few ponies due to it being able to flow more air and fuel than the carb .
  22. Likes XstreamVking liked this post
  1. Truck cap or no truck cap for hauling boat
    By aggiestckl in forum General Boating Discussion
    Last Post: 02-08-2015, 01:28 PM
  2. MEGA TRUCK "Monster Truck" Chevy Stroker
    By roosterds650 in forum Non-Marine Items
    Last Post: 04-10-2014, 04:37 PM
  3. My new tow truck!
    By JUPITER PULSARE in forum Tow Vehicles and Trailers
    Last Post: 05-05-2011, 04:54 PM
  4. Used Car/Truck HELP!!
    By wing nut in forum The Scream And Fly Lounge
    Last Post: 01-23-2010, 09:54 PM
  5. So I went out with my dad looking for a new truck for him.
    By Capt.Insane-o in forum The Scream And Fly Lounge
    Last Post: 01-22-2010, 07:18 AM
