Results 46 to 60 of 75
Thread: 1993 Johnson 140s / F233
02-04-2018, 06:59 PM #46Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Yah sure, raise the motors up take it for ride. Maybe that's been said a few times.
02-04-2018, 11:22 PM #47Member
- Oct 2017
- Charlotte NC
- 30
02-04-2018, 11:35 PM #48Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
It won't loose hold in a big swell with chop on top.
reelbrothers liked this post
02-04-2018, 11:43 PM #49Member
- Oct 2017
- Charlotte NC
- 30
he sold that one, he's looking at a center console model to restore now,
next question on the engines, I believe they are 9 amp charge , can hey be upgraded for higher output? I'm just thinking about trolling at low rpm and running electronics, live well ect..
02-04-2018, 11:51 PM #50Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
02-04-2018, 11:53 PM #51Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
02-04-2018, 11:55 PM #52Member
- Oct 2017
- Charlotte NC
- 30
we are gonna go up one hole
02-05-2018, 12:00 AM #53Member
- Oct 2017
- Charlotte NC
- 30
02-05-2018, 07:31 AM #54Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
02-05-2018, 04:51 PM #55
you can go up one hole but its a waste of time. go up as high as possible ,but it still wont be enough. you need to go up around 7 inches to be at normal height.
if it was mine u would make my own plates and go up atleast 7 inches.. you need the cav plate roughly level with the box bottom.
and with the motors set back that far it will easy handle swells no problems, these boats ride with the back end down a bit anyway.
if they were 20 inch motors you could possibly get away with using the clamp at its highest setting.. but not with xxl mids.
take it up all the way, then see if any improvement. just 1 hole is not going to make any difference.
02-05-2018, 07:01 PM #56Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
02-05-2018, 09:14 PM #57
Has not been mentioned yet.... also make sure the box isn't filling up with water....................
phillnjack liked this post
02-19-2018, 10:29 PM #58Member
- Oct 2017
- Charlotte NC
- 30
ok, got head gaskets, carson reeds and carbs rebuilt, pumped the bulb, hit the squirter and she fired right up, that's the good, now I can't get the idle down from 2000...what am I missing, shold look for..shouldn't be an air leak, I opened the squirter lever aND it smoked and stalled out, figure if air getting in more fuel would increase rpm even more.
thanks guys.
02-19-2018, 10:57 PM #59Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
check all throttle butterflys are closed at idle
02-19-2018, 11:09 PM #60
Check your synch and link........ idle timing etc.......... The spaghetti seals behind the carbs are easy to have one slip and suck air.
powerabout liked this post
'95 XR6 2.5 200 HOURS NEVER OPENED FACTORY PSI 140s
By CircleHook in forum Outboard EnginesReplies: 6Last Post: 10-16-2016, 06:11 PM -
1993 Johnson 25
By clayton bigsby in forum Outboard EnginesReplies: 3Last Post: 12-06-2015, 05:22 PM -
1993 Johnson 150
By rickriddle in forum Technical DiscussionReplies: 1Last Post: 05-08-2010, 08:06 PM -
1993 Johnson 275 V-8, worth??
By towman2277 in forum Technical DiscussionReplies: 16Last Post: 07-27-2007, 06:48 AM -
1993 Johnson 150
By pp185xlt in forum Technical DiscussionReplies: 6Last Post: 06-21-2007, 02:25 PM
