Results 46 to 60 of 100
Thread: Opti low rpms
02-02-2018, 12:20 PM #46Member
- Jan 2018
- Florida
- 97
All good man, i appreciate the help!!
02-08-2018, 10:12 PM #47Member
- Jan 2018
- Florida
- 97
02-08-2018, 10:15 PM #48"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
02-08-2018, 11:36 PM #49Member
- Jan 2018
- Florida
- 97
02-20-2018, 06:42 PM #50Member
- Jan 2018
- Florida
- 97
Unfortunatly i have not had time to do anything with the boat. Im posting a video os what the motor does on cold starts or when it has been sitting for about an hour or more.
https://m.youtube.com/watch?v=9zSeC9D1LCc
02-20-2018, 11:29 PM #51
From the sound of it. I think it may have been used to much when it was new.
02-21-2018, 02:23 AM #52
I'd run an injector self test on it, specifically the air. It's easy to tell aubilby which one(s) do not belong. Look at your harnesses carefully too, especially the fuse holders.
02-21-2018, 11:57 AM #53Member
- Jan 2018
- Florida
- 97
How do i do that. It runs fine n smooth once it warms up.
02-26-2018, 06:08 PM #54Member
- Jan 2018
- Florida
- 97
Update!! I fixed the starting issue, torn fuel regulator diaphram and there was a pin hole in the air diaphram
davemvegas liked this post
02-26-2018, 09:07 PM #55Member
- Jan 2018
- Florida
- 97
As for the low wot rpms. Should i try messing with the engine mount height? Motor sits on a 30inch bracket off the transom, i layed a straight edge o the keel and with the anti vent plate on the motor level with the keel the straight edge sits about 3inches below the plate... i know the rule of thumb is 1inch per 1foot off the transom but my boat has a very deep V in back so im wondering if i should be higher? The prop dosent blow out unless i trim well past normal running height.
02-26-2018, 09:21 PM #56"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
02-26-2018, 09:47 PM #576000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
We’re the injectors cleaned after the compressor went poof, if you have the square fuel pump it probably needs rebuilt ( you got psi but not flow) it’s the low pressure vacuumed pump. Ummm
the ring injectors can short to ground.
Just a side note even even the old power head seems low on rpm. I don’t remember the spec but you should have been turning over 5500 iirc. (Tachometer can be inaccurate though) you could actually be overpitched but it should iirc set a overpitch code.
The slack if for the gaurdian system. Opti are tough to keep up with several changes over the yers
02-26-2018, 10:50 PM #58Member
- Jan 2018
- Florida
- 97
yea im going to look at it next time i run it, gotta get my tabs working first so i can drop the bow and get an accurate measure. Im running a mirage 21p, the old powerhead turnd this prop 5600+ all day. Also one of these days when i get time i need you to scan the motor. I still think i have a sensor somewhere thats bad.
02-26-2018, 10:53 PM #59Member
- Jan 2018
- Florida
- 97
No smartcraft gauges, my opti is an 02. So it has the big vst on the port side bolted to the air handler, high and low pumps are brand new.. no injectors were never cleaned. I replaced the rails with another motor but i used the same air injectors. Could be a problem with them but idk amd one local to test them with out costing me a ton of money. Im just a poor boy trying to fix up my dads old boat lol
02-26-2018, 10:58 PM #60Member
- Jan 2018
- Florida
- 97
CORRECTION. 19p 3 blade mirage stainless prop.
i have another ecm, would that be even worth a try? Motor runs 10 times better now with fixing the diaphrams. So another sea trial needs to happen eather way. Hard to get an accurate idea with 10 people and 3 loaded coolers on board haha.
Regular 225 Opti vs 250 Opti XS
By stingray240cs in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 9Last Post: 02-06-2018, 03:28 PM -
Low rpms on 200 opti
By Akgravelpumper in forum Technical DiscussionReplies: 4Last Post: 02-04-2018, 04:28 PM -
Mercury Tech: RPMs bouncing over 6000 rpms
By 2 De River in forum Technical DiscussionReplies: 5Last Post: 09-19-2009, 06:52 PM -
Engine life? less RPMs more load or more rpms less load
By stvhelm in forum Technical DiscussionReplies: 24Last Post: 04-28-2008, 08:13 PM -
Dual Repower 225 opti, 225xs or 250xs/opti
By fishnchips in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 10Last Post: 02-18-2008, 08:18 PM
