Results 16 to 21 of 21
Thread: Mercury Opti Air Pump...
02-07-2018, 07:08 PM #16"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
02-07-2018, 07:57 PM #17Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
02-07-2018, 08:22 PM #18Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Little N2O mixed in would give it a kick,,,,,,
02-08-2018, 11:36 AM #195000 RPM
- Jun 2017
- Connecticut
- 263
- 38
- 19
- 33
- 21
Some thoughts:
The current air compressor appears to produce alot of excess air most of which is dumped by the pressure regulator compared to how much is passing through the air injectors. The air injector are tiny and only open for short period in comparison to the regulator.
Per the design of the atomizers there is a pressure that is optimal for fuel atomization. Slow down the compressor speed and you will get larger variations in air pressure.
The cam and bearing were the weak points especially in the early compressor design. You would need some advanced engineering/modeling to figure out if slowing down vs Less air compression force(smaller piston) would put smaller more stable loads on the compressor cam/bearing.
Tango liked this post
02-08-2018, 11:44 AM #20
This is why I feel just using a higher quality, ceramic coated & lighter piston will prevail as the needed measure. Reducing drag, weight, load and wear to the bearings should remedy the majority of causes for the pump failure.
Every other measure would require much engineering and effort to redesign the wheel.
Fishinmymission liked this post
02-08-2018, 11:53 AM #215000 RPM
- Jun 2017
- Connecticut
- 263
- 38
- 19
- 33
- 21
I agree with you. If you can reduce the weight of piston and the piston is robust enough to never fail it would only benefit the cam and bearing.
Oil pump om 2005 225 opti
By XstreamVking in forum Technical DiscussionReplies: 3Last Post: 02-13-2013, 11:12 AM -
2001 Opti fuel pump
By Cobra1racer in forum Technical DiscussionReplies: 4Last Post: 10-19-2010, 08:50 PM -
Mercury Tech: Opti Max air pump question
By captglm in forum Technical DiscussionReplies: 3Last Post: 12-14-2009, 03:44 PM
