Results 1 to 6 of 6
01-21-2018, 12:42 PM #1
Foam board that will accept Resin?
Is there a styrofoam that can be fiberglassed on both sides and not be destroyed by Poly or vinyl resin?
01-21-2018, 02:08 PM #2Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
Styrofoam is only used with epoxy as far as I know...
01-21-2018, 06:39 PM #35000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
Correct me if I'm wrong but I have seen lots of flotation foam glassed in. I have used 1/2 styrofoam just as a insulator and filler on a cooler. I put it down and glassed over it. The resin didn't seem to hurt it 'too much' but all I was doing was trying to create airspace for insulation. And yes I am sure the results would be better with epoxy.
01-21-2018, 07:11 PM #4Scream And Fly VIP
- Jan 2007
- Amityville/Lindenhurst
- 3,012
- 46
- 18
- 204
Flotation foam is urethane, it’s not styrofoam
there is some foams that work
Duartec sells something you can spray on cheap foams supposed to keep them from melting. Really intended for plug/mold making.Raybo Marine http://www.raybomarine.com/
01-22-2018, 02:46 PM #57000 RPM
- Central Florida
- 2,643
- 37
- 32
- 219
"Styrofoam" can't be used with styrene based resins like polyester or vinylester. It will disolve as they are all styrene based. As mentioned earlier, epoxy is ok for Styrofoam.
Numerous other foams are ok but probably not as cheap.
01-22-2018, 03:00 PM #6Scream And Fly VIP
- Jan 2007
- 3,012
- 46
- 18
- 204
Wraping hi density foam into tight places without using heat and makingthe foam hard
By tunnels in forum Fiberglass and Composites DiscussionReplies: 11Last Post: 01-22-2017, 05:54 PM -
Foam sheet or pourable foam?
By bigboy in forum Fiberglass and Composites DiscussionReplies: 2Last Post: 11-03-2010, 02:01 AM -
Will my 12 JE berkley pump accept a Jetovator
By 79Wreidt in forum Jet Boats, V-Drives and Stern DrivesReplies: 5Last Post: 08-21-2009, 10:44 PM -
Polyester resin over epoxy resin adhesion
By Techno in forum Fiberglass and Composites DiscussionReplies: 6Last Post: 04-01-2004, 08:31 PM -
New composite marine foam board
By TTriton in forum Technical DiscussionReplies: 7Last Post: 11-09-2001, 09:38 PM
