Results 1 to 5 of 5
Thread: Best Paint
    Nov 2009
    long island NY
    Best Paint
    Hello. Im going to repaint my boat. What is the strongest most durable paint for the bottom?
    Imron, Dupont? Etc.
    Single stage or base coat clear coat?
    Thank You
    Sep 2017
    ontario
    Painter by trade - automotive and if your not going to flip it and gel coat it , first choice . I suspect urethane to be a good choice .High quality - high solid urethane is the next best. Prep work is the first step to the top coat and of course straighten it out a bit and sand it and do edges well . You sure you can't buff the gel coat and continue to keep the original sir , that's always a nice way to keep original and costs nothing other than compound and some work . That's is good advice . Keep it original and when you sell it its still original .
    I live in Prineville Oregon which is in the central part of the state
    I have sprayed a lot of boat bottoms with Dupont Imron and I have seen nothing better. I had a boat in the water for three months straight and not one blister. If there is something truly better I have not seen it yet.
    Best wishes, Carter Powell
  4. Likes LakeFever, sonicss33 liked this post
    35 Post(s)
    Nothing Trully Better and Also Deadlier
    Quote Originally Posted by Carter Powell View Post
    Imron is tough and will flow over surface inclusions like no other. But it is also deadlier (polyisocyanate). Only way you fool with this stuff is with a full up air fed disposable tedlar suit and helmet and nitrile gloves. Don't be stupid enough to spray Imron with a Covid19 N95 mask. Fumes will eventually kill you. I'm not even sure if you can buy Imron from a distributor without being certified on how handle and use it. Dupont Centari is just as nasty.
  6. Thanks doug7488 thanked for this post
    Jun 2018
    Floating around
    We did a 1968 aluminum starcraft with imron in the 80’s. This boat is still owned by the same guy and it lives in the water from april to ovtober every year and it still looks as good as it ever did. Tough tough paint
    but yes, quite hazardous be careful
  1. Best Prep/Primer/Paint combo to keep paint on LU?
    By imq707s in forum General Boating Discussion
    Last Post: 10-08-2019, 11:44 AM
  2. Can paint stripper be used to remove paint from gelcoat?
    By mrcrsr in forum Fiberglass and Composites Discussion
    Last Post: 08-16-2017, 07:23 AM
  3. what paint for custom paint with multiple colors?
    By simplyorange in forum Appearance Mods
    Last Post: 10-05-2011, 03:44 PM
  4. Ever paint your Garage floor?? Looking for a good paint product.
    By Daytona19 in forum The Scream And Fly Lounge
    Last Post: 05-23-2003, 03:29 PM
  5. Good paint gun choice for paint/clear?...
    By C. Phillips in forum Fiberglass and Composites Discussion
    Last Post: 02-12-2003, 08:55 AM
