Results 16 to 30 of 36
01-19-2018, 03:07 PM #165000 RPM
- Sep 2017
- Saugatuck, Michigan
- 318
The 2.7 heads came with the boat when I purchased it along with two other complete built powerheads
01-19-2018, 07:09 PM #175000 RPM
- Sep 2017
- 318
Do you have a part number for the send unit you used ?
Thanks Bart
01-19-2018, 08:44 PM #18
definitely better off with the gauge rather than daft over heat buzzers, when and if they work you are correct its too late, and you dont even know if they do work.
with a gauge you know exactly whats going on.
I put my sender in the already drilled and tapped hole, works perfect. dead easy to fit.. the threaded part of the sender also sends the temp, its not just the prop on the end.
01-19-2018, 09:01 PM #195000 RPM
- Sep 2017
- 318
Yes I agree...
I just ordered omc sending units ....i think I got the last 4 on eBay. Have to match 4 gauges to those send units.
Out of curiousity...where did you still and tap your send units ?
01-19-2018, 09:02 PM #20
01-19-2018, 09:03 PM #215000 RPM
- Sep 2017
- 318
Sorry...my bad, I read your post wrong. The stock hole in the head .
01-19-2018, 09:05 PM #225000 RPM
- Sep 2017
- 318
Thanks ...i just ordered 4 OMC 172843 send units.
01-19-2018, 10:28 PM #23Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
Water pressure would be the next gauge i would have after the tacho then fuel pressure
01-20-2018, 12:16 AM #245000 RPM
- Sep 2017
- 318
I have new Levorsi water pres gauges at the helm and fuel pres gauges at the motors....holley blue pumps regulated to 4.5 psi
Should be in good shape after install of water temp gauges.
01-20-2018, 11:27 AM #25
99.9% of temp senders on cars are perfect for the head on omc, they are the same thread.
you do NOT need to get a matching gauge for the sender, thats a myth... the sender just lets through more voltage (earth) as it gets hotter.
I have mercury , omc , smiths, jaeger, Durite and the cheapest nastiest Chinese gauges you could buy and all register the same with just a normal car sender.
its just a 1/8 npt.
the brass body and threads are enough to get the temp, and no putting it into water, you want the head temp not the water temp.
here is my little sender, very cheap and works perfect.
some people put dielectric grease on these, there realy is no need as the threaded part gets the temp too.
.Last edited by phillnjack; 01-20-2018 at 11:31 AM.
01-20-2018, 11:56 AM #265000 RPM
- Sep 2017
- 318
Awesome Phil.....tks for the input
I do have 4 new OMC senders coming...they were $20 ea with free ship, only a few bucks more than a universal. Also just ordered 4 Sierra temp gauges and a quad pod for mounting.
Bart
01-21-2018, 09:47 PM #276000 RPM
- Sep 2002
- Solvang, Calif
- 1,459
- 78
- 29
- 160
- 155
I used digital pyrometers with exposed tips. Tips directly into the water. Paid for it's self when the water pick up got a plastic bag over it. Guage has a red led that flashes if over threshold setting.
Gary
01-21-2018, 10:37 PM #285000 RPM
- Sep 2017
- 318
Sounds like a fail safe set up....
Gauges on the helm are pretty easy to ignore especially at high speeds....
These new temp gauges will be in full view just above steer wheel.
B
01-22-2018, 07:45 PM #29
measuring the water is not the right thing to measure, these are not sealed circulation, its head temp your after... check head temps with infra red fin or normal way then compare.
personally I think outboards should come brand new with water temp gauges and the motor cut out if 20c deg over, then go into limp until cooled down.
my motor has the S.L.O.W feature, nut that will only come in at way too hot temp for my liking..
01-22-2018, 09:19 PM #305000 RPM
- Sep 2017
- 318
oem temp send units should measure head temp .being they are bottomed out in the head...realisticly doing the same thing as the too late buzzer but at least you can see it coming.
how and where do i install temp probes for pyrometers in 2.5 260
By aggiestckl in forum Technical DiscussionReplies: 4Last Post: 08-30-2013, 08:55 AM -
Mercury Tech: Temp sendnig unit for Merc H-C gauge install question (contact block or just water)
By bmcalpine in forum Technical DiscussionReplies: 0Last Post: 07-15-2012, 05:21 PM -
best place to send a block for a sleeve install ?
By WATERWINGS in forum Technical DiscussionReplies: 21Last Post: 04-20-2012, 07:23 PM -
Who can I send a 75 hp Johnson Stinger to for modification?
By john rowley in forum Technical DiscussionReplies: 1Last Post: 06-22-2010, 08:00 AM -
trying to re-install lower unit,,,help...
By Budlight in forum Technical DiscussionReplies: 13Last Post: 08-11-2007, 02:16 PM
