Results 1 to 7 of 7
    Wyoming Pa
    Need help with serial number
    Hi, I picked up a late 80's merc 200. 2.5L this fall to work on. The serial number tag is missing on the motor. Is there another way to find out what the serial number is? Or is in on the motor somewere?
    Thanks in advance.
    Rob
    TX......somewhere?
    first thing is tha 2.5 200 didn't show till '91 in a 7 petal front version.. only year with tha 7 petal.. look on tha welsh plug on top of tha block and/or on tha port side case half flange.. also will be a "build date" stamped at tha bottom of number 2 on tha block half.. kinda right behind tha bend in tha timin' arm.. will be 1/8" numbers.. m/d/yr.
    post some pics of it.. (power head)
    Wyoming Pa
Name:	20180115_061121 - Copy.jpg
ID:	397422Click image for larger version.
Name:	20180115_061129 - Copy.jpg
ID:	397423Click image for larger version.
Name:	20180115_061148 - Copy.jpg
ID:	397424Click image for larger version.
Name:	20180115_061058 - Copy.jpg
ID:	397425These are some pics of the motor. I did find the date, 041487. I think it's an 87, but is it a 200 or did someone change the cowling?
    TX......somewhere?
    2.4 200.. only one that year with horizontal front
    Wyoming Pa
    so it's 2.4 not a 2.5. I need to get some parts for it like the stator, trigger, switchboxes, rectifier, regulator and fuel pump.
    TX......somewhere?
    http://www.marineengine.com/parts/me...-thru-0c100860
    this should get whatcha need.........
    Wyoming Pa
    Thank you for the help.
  1. Serial number look up help
    By YELLOWSS in forum Technical Discussion
    Last Post: 04-24-2014, 02:47 PM
  2. Mercury Tech: Serial Number
    By moomba in forum Technical Discussion
    Last Post: 12-05-2012, 10:23 PM
  3. serial number
    By sicknick12 in forum Technical Discussion
    Last Post: 03-24-2008, 08:48 PM
  4. Serial number help
    By Dave@DunnWright in forum General Boating Discussion
    Last Post: 07-04-2004, 11:51 AM
