Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
    I'm hopeful, .185+/- thick will help with the extra stuffing after removing case material to help flow. Had to ask a couple times, 0.18.....
  2. #17
    Jun 2020
    upstateS.C./sevierville TN.
    There are no instructions.wont fit correctly without milling the back mounting stops about .030 to allow the staffers to be flush
  3. #18
    Mar 2004
    Brooklyn Park, MN
    Quote Originally Posted by troop View Post
    Give him a call, something is up and he will walk you through this.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  4. #19
    Feb 2006
    What's it on? I had to clearance the block on a 2.6 Yamaha 200 last year. Wasn't cool because the rotating assembly was done.
  5. #20
    Sep 2006
    Key Largo, Fl
    305-394-3354,Chris
  6. #21
    MIAMI FLORIDA
    I had to cut the cage bosses slightly on a 2cyl omc install, also put the stuffers and cages on the intake with the reed block screws slightly loose let the cages and spacers center themselves in the front half and then you can tighten the Reed block screws... Worked for me anyway. The Reeds and stuffers made a noticeable increase in mid range pull on my little 45ci rude.
  7. Thanks Instigator thanked for this post
    Likes Instigator liked this post
  8. #22
    7 Post(s)
    So the ONE guy, making these, produces parts that need a bit of finess fit……., I’m OK W/that.
    Yrs back, I had a set for a V-6 OMC looper and they were from whoever produced them for the OMC racing division and they wouldn’t even go into the case without work!
    Kinda like me bitching to Wayne Taylor about the quality of his hot rod OMC pt’s and then realizing, No one else even made them!
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  9. #23
    MIAMI FLORIDA
    Agree.. were putting the parts on motors that were made over a course of 40years im sure the tolerances/changes are numerous on the blocks and cages, omc has 4 or 5 different 4 petal cages that will all bolt up but have differences and numerus block part numbers for the same engines so there's no way you can make a one size fits all with a perfect fit. There is the question one gasket or two ?
  10. Likes Instigator liked this post
  11. #24
    7 Post(s)
    Chris, save me 3 sets, plus.
  12. #25
    Sep 2006
    Key Largo, Fl
    Gary,Thanks for your support.We are making stuffers for lots of motors,and over the years small changes come along in some motor types that may cause a need for minor fitment work.For example,while the 4,5 and 6 petal stuffers always are a drop in fit,sometimes the 7 petal cages will need a little trimmed from the back side of the mounting bosses should they bottom out in their respective pockets in the crankcase front,to facilitate a flush fit.
    Vertical reed yamaha 4 and 6 cylinder motors may need the stuffers trimmed a bit to fit properly,but this is easily done as the stuffers are fiberglass,and cut/sand easily...and cutting in the crankcase front is not necessary.
    If anyone is having trouble,they are urged to call me,and we will resolve whatever issue there might be.
    We have expanded the offerings quite a bit,covering all the v4 and 6 yamahas,OMC loopers,fichts,Etecs,40-60 twins,and 49-56 triples,Merc 2.0,2.4,2.5,3.0,3.2 liter v 6's,carb,efi,and opti's.
    Overall,the stuffer program has been very well liked,with only 1(one)set returned out of hundreds...buyer said the 5 petal merc stuffer wouldn't fit because it wasn't cut evenly,and returned them before I could tell him the cut was deliberate...look at the crankcase front.
    Some motors and setups benefit more than others,and some like the etec and hpdi direct injected motors idle and accellerate so much better we always get comments from customers that use them.
    Anyway,they are a drop-in fit on most motors,and if needed fitment can be made without grinding in the crankcase...
    The beauty in these little parts is the fact that they achieve the same or usually better crankcase compression gain than milling the crankcase front,and do so without changing the external dimensions of the motor...leaving all throttle,tps,etc linkages without needing changes,Chris
  13. Thanks Instigator thanked for this post
  14. #26
    Mar 2015
    DFW
    so I'm just a country bumpkin and don't think I understand what these things do. They go inside the reed plate, under the reed cage, to space the reed cage back, towards the crankcase?
    STV Pro Comp Ski| 200 Merc
  15. #27
    Sep 2006
    Key Largo, Fl
    Quote Originally Posted by Noah Burns View Post
    Exactly,and fill in the area around the foot of the reed cage as well in most instances,Chris
  16. Thanks Noah Burns thanked for this post
    Likes Noah Burns liked this post
  17. #28
    Mar 2004
    Brooklyn Park, MN
    The less volume you have in the crankcase results are the engine will go into a vacuum sooner and longer and also on the blow side of pushing more air/fuel into the cylinders. Very clever solution to doing this without machining and epoxy/welding!
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  18. Likes LakeFever, Instigator liked this post
  19. #29
    Quote Originally Posted by ChrisCarsonMarine View Post
    I had a fella ask me about reeds the other day. I told him (many others) that I only use Carson reeds.
    Seems no matter if it's your cell phone or the Mrs. washing machine, in this day and age you either have to listen to elevator music for a half hour or speak to someone that doesn't speak English.
    I have yet to not be able to speak to Chris directly when I have called. Or if busy, to not call me back before the sun sets. A wealth of knowledge + service ..
  20. Thanks Instigator thanked for this post
  1. Replies: 3
    Last Post: 06-21-2018, 04:05 PM
  2. Rebuilding and Debugging by Chris Carson's Marine Service
    By fmaxwell in forum Technical Discussion
    Last Post: 11-26-2017, 09:59 AM
  3. Mercury Tech: Chris Carson Reeds and Brucato Injector service
    By gcplowboy in forum Technical Discussion
    Last Post: 08-22-2012, 09:50 AM
  4. Chris Carson Marine = Great products and customer service!
    By Mr. Demeanor in forum General Boating Discussion
    Last Post: 12-20-2011, 12:11 AM
  5. Chris Carson Marine..........
    By Jay R. in forum Technical Discussion
    Last Post: 01-21-2011, 07:09 AM
