Results 1 to 15 of 29
    Exclamation New Crankcase Stuffer Plates from Chris Carson's Marine Service
    An Easy and Fast Modification For Mercury Engines
    Chris Carson’s Marine is adding several new products to compliment our reed valves and spacer kits, focusing on the small block V6 Mercury engines.
    This is an inexpensive modification that can easily be performed while changing the reeds, with no added strain on the engine and no penalty to long-term reliability.
    Now available are new intake stuffers that mount between the reed blocks and intake manifold, reducing the crankcase volume by moving the reeds into the crankcase .065-inch. This modification results in the exact same gain as with the common practice of milling the front half of the crankcase, but without the need to tear down the engine or any machine work.
    The five and seven-petal versions are available now and ready to ship, with an even more effective version for the four-petal engines becoming available within a few days.
    Chris Carson's Marine Service will be offering other valuable engine crankcase stuffer products for other engines very soon.
    • Chris Carson's Marine Service Website
    Very nice!
    Chris and I had a conversation about these the other day. I think these should yield good results without touching/cutting the front 1/2 or block.
    minocqua, wis
    What's the price ? 7 petal
    Sep 2006
    Key Largo, Fl
    7 petal 85$,5 petal 75$,4 petal(much thicker)85$,Chris
  5. Likes Scream And Fly liked this post
    May 2002
    NY, Long Island
    They look good! Has any testing been done on these to validate seat of the pants results?
    "If everything's under control, you're going too slow"
    -Mario Andretti-
    76 vixen,.. on the back burner
    82 laser comp. 380 ray
    PICS OF THE VIXEN REBUILD
    Sep 2006
    Key Largo, Fl
    Quote Originally Posted by wing nut View Post
    No dyno test, but I have to think it will be a improvement because it’s kind of standard to mill 050 from the crankcase front when you’re doing a high-performance build, these do the same thing and start at 065,the 4 petal reeds can go much thicker,Chris
    OK so do I use them on worked five finger or stock coated four fingers?
  9. #8
    Sep 2006
    Key Largo, Fl
    The height dimension of the five petal reed will allow the 065 stuffer, the four petal will allow a much thicker stuffer, because it is not as high. I originally cut the four pedal stuffers from .186 material, and some motors they fit and on some motors there just a tad high, this can be easily sanded for a perfect fit,Or you can wait about a week for me to get the .125 stuffers completed. They will fit with no modifications. You have a call if you’d like to discuss them, Chris
  10. #9
    Aug 2002
    Palm Harbor, Fl../ lake tarpon
    Pretty cool should sell like hot cakes
    02 mirage ski racer w/ 2.5
    lake tarpon (LTB racing)
    "Mirage Boats... often imitated but never duplicated"
  11. #10
    Belgium
    So what performance gain can be expected? Better acceleration? More top-end?
    Rejetting needed after installation?
    Thanks
    http://www.geocities.com/fletcher_arrowbeau
    Fletcher 17F6
    Hydrostream HST 20F
  12. #11
    Sep 2006
    Key Largo, Fl
    Same gains as milling the crankcase front,a little better performance all the way around I would think,without tearing down the motor,Chris
  13. #12
    Sep 2006
    Key Largo, Fl
    Corrected post 8 regarding thickness for the 4 petal cages,Chris
  14. Thanks Apex2007 thanked for this post
  15. #13
    Mar 2017
    Miami, FL
    Any gains on a stock 2.4 200? Or is this for a higher performance application?
  16. #14
    Sep 2006
    Key Largo, Fl
    Pretty sure this will help even with stock motors...
  17. #15
    7 Post(s)
    Nicely done Chris.
    Every hot rod OMC I've ever built, I cut the front half.
    Whether you can feel it by itself is debatable but, I wouldn't put a set of reeds in a Merc w/o those shims.
    A motor is an air pump. The more you can reduce the volume inside the crankcase, the more efficient the air pump.
    On a modded motor it would be even more pronounced.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  18. Likes FORBESAUTO liked this post
  1. Replies: 3
    Last Post: 06-21-2018, 04:05 PM
  2. Rebuilding and Debugging by Chris Carson's Marine Service
    By fmaxwell in forum Technical Discussion
    Last Post: 11-26-2017, 09:59 AM
  3. Mercury Tech: Chris Carson Reeds and Brucato Injector service
    By gcplowboy in forum Technical Discussion
    Last Post: 08-22-2012, 09:50 AM
  4. Chris Carson Marine = Great products and customer service!
    By Mr. Demeanor in forum General Boating Discussion
    Last Post: 12-20-2011, 12:11 AM
  5. Chris Carson Marine..........
    By Jay R. in forum Technical Discussion
    Last Post: 01-21-2011, 07:09 AM
