Results 1 to 12 of 12
    Apr 2016
    Victoria bc canada
    Best ECU/fuel curve for drag cut 260???
    Looking for opinions on which ECU and fuel curve to use on a modified drag cut 260, zero hour since new nic and rebuild, motor is an early 260, 5250 rods, merc top pinned pistons, angle cut reed plate, 1" spacer, bored out horn, CCM reeds, will be running 34cc heads for lake and 26cc for racing. Thanks!
    15.5 cobra 175 hp merc - sold
    18 tahiti tiger O/B 200 hp merc - sold
    19 STV euro - 245 hp merc
    shreveport,la
    A6 or A63 hard going to be very hard to beat
    Erik Kiser
    Apr 2016
    Victoria bc canada
    Quote Originally Posted by patchesII View Post
    So move up to a 56lb reg and go with that A6/A63 drag box? What are your thoughts on ACU vs merc ECU?
    WI
    My buddy and I run a Merc 11350 ecu with an A48 w/ 39lb reg for lake boating and an A63 w/ 56lb reg for drag racing on his boat.....you can swap the chip easily enough to do either but I've seen the A48 curve work very well for both if the boat is not a tater chip. The 849849 boxes would work great if you had one with several curves for both regulators and the ability to switch out/modify the curves with a laptop, but the 11350 boxes do the job just fine.
    I have a boat or two.... that I never get to drive
    a6 is not a ride on the lake map. I'd get an ACU for lake use and a stand alone ecu for racing.
    Paulina, LA
    My motor is basically the same without the angle cut spacer. Mine isn’t cut. I run 165-170# compression. I run an 39# acu system. I told tony what my motor was and he sent what he thought would work. I run an adjustable regulator set about 5more lbs than a standard regulator puts out. It’s a great setup.
    Apr 2016
    Victoria bc canada
    Why wouldn't you want to run the A6 for lake use?
    Jul 2009
    Crawfordville fl
    Get a acu and have Todd evolution marine put u a curve in it. You will be very happy
    Nitrous is like a slut. u wanna hit it but you know there will be consequences.
    Paulina, LA
    I just did that very thing actually. Brought Todd my ACU Friday and picked it up Saturday. Heard Todd is one of the best when it comes to tuning and ACU/PCU. Been raining since yesterday but hope to do some testing this week.
    Dec 2011
    Ludington michigan,on the shore
    Sounds like you got it covered.The A48 curve has served me well.
  11. Likes NICE PAIR liked this post
  12. #11
    Apr 2016
    Victoria bc canada
    Ended up going with a brand new ACU and steamwheel from brucato
  13. #12
    Paulina, LA
    I used to like the A48. When it went out is when Tony started putting the steam wheel with the ACU so decided to go that route.
  1. Mercury Tech: Fuel curve
    By fireedge11 in forum Technical Discussion
    Last Post: 07-03-2010, 01:07 PM
  2. Mercury Tech: fuel curve ????
    By patchesII in forum Technical Discussion
    Last Post: 07-02-2009, 08:24 PM
  3. A49 fuel curve?
    By STV_Keith in forum Technical Discussion
    Last Post: 04-22-2006, 04:59 PM
  4. When should the fuel curve be remapped
    By trey in forum Technical Discussion
    Last Post: 06-22-2001, 01:48 PM
Mazco
