Page 37 of 51 FirstFirst ... 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 LastLast
Results 541 to 555 of 764
  1. #541
    7 Post(s)
    I’ll bet you a 12 pack ours are the same hulls.
    They built a 24’, IO and OB, the Enforcer.
    Why would they build that and a 24’4” Convincor.
    Advertised weights are often just that.
    Advertised.
    I know boats fairly well and I know Checkmates fairly well.
    Ive had mine down to bare hull and I don’t see anyway to shave off 650 lbs.
    50 maybe....
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  2. #542
    Jul 2005
    AZ
    Yea it's 24' 2" give or take an inch hard to measure by myself and cover on.
    That's why I figured the guy I was talking to had an idea because he knew it was only 24'
    '84 Checkmate Convincor
  3. #543
    Jul 2005
    AZ
    I have know idea and DO not claim to have any answer or know..lol
    That's why I was asking and curious..now I'm going to have to weigh it again at some point..after being ocd about it last time
    Like I said it all depends the factory seats I took out weighted over 125# a piece..
    I thought back then that it might be different model because of the length but I checked the HIN and it's a convincor
    Have to start researching again and see if it is one of 4 24' + ..If anyone even has a clue
  4. #544
    7 Post(s)
    Guess I was cornfused.
    I thought you were anxious for me to weigh mine because you hadn’t weighed yours.
  5. #545
    Jul 2005
    AZ
    Oh I had weighted mine but I wanted to know how much yours was because I was told they were heavier.
    I was trying to get info and put pieces together of info I was told.
    Oh did you measure yours? Convincor 251
    As for advertised weight? I don't know what they had in the boat seats etc but..
    I'm now going with actual weight.
    I'm trying to look at all the pics but if you start with I don't have a windshield how much does that hatch weigh?
    I took out hundreds of #s
    between the heavy ass seats
    All the plywood stuff in the cabin and other stuff..
    But I'm really looking to see if they are different .
    Like is yours 25'
    If that nonsense makes any sense..
    Oh still need to call you about props I keep forgetting and now the time difference
  6. #546
    Jul 2005
    AZ
    Gary need more pics..how's the pad coming?
    Oh can you take a pic of your hatch area and transom?
    Oh and you have a full swim platform bracket how much does that weight?..so the difference of 650# rigged is probably easy to find.
    What props are you going to start with?
  7. #547
    Oct 2020
    Alaska
    The later Ones are much more refined you will like them. Better ignition, better map and improved oiling but there’s an oil trough behind the sleeve. It lets oil out of a hole in the sleeve puts oil between the exhaust port and top transfer port. Well when the block cracks that oil hole pumps sea water out of it instead of oil fishing tackle abu dhabi. I’ve never met a dealer that’s herd of this problem but that’s cause they just call Evinrude and get a new Powerhead. I end up with the broken stuff and it usually rusts out the crank which is 3.4 specific $1700 dealer cost.
  8. #548
    7 Post(s)
    It’s alive!
    Splashed it today.
    Main focus was to see if the motors would rip off the glass bracket I built for it.
    Like many told me it would.
    I put the jack plates all the way down where the props would put the most torque on the top of the bracket then lit the motors.
    Did this several times then pulled it up the ramp to check the seam where the bracket mates to the transom to see if it opened up that joint.
    It did not.
    Yah!
    Pulled it off trailer to see what’s what.
    Port motor needs tuned and (I didn’t bring those tools) and was dying at idle.
    Was 45* today and lake is way down for winter so is basically a narrow, short creek.
    I was very limited for open water.
    Focused again on bracket integrity (motors fall off I want that to happen now before wasting a winter working on the boat) and did a half dozen full throttle hole shots w/motors full down.
    Pulled it back out to check joint between bracket and transom and was perfect.
    So I got a couple of 40 mph passes and pulled the plug.
    W/all the variables, I’ll take it!
    Attached Thumbnails Attached Thumbnails 694C44A7-B0C0-4FA4-B653-56645DB2D805.jpg   B8407CAF-7112-4FD3-A5D4-817B1341D474.jpg   C0C57284-63EB-465E-9355-EBA09E1E1CCE.jpg
  9. #549
    Mar 2002
    N.E. Ohio
    Hell yeah! Great news
    Mirage Jaguar RiverRacer
    Polaris PRO785
    Bennington 255LCC
    Scream & Fly Flying Machine of the Month:
    September 2005
    http://www.screamandfly.com/showthre...ild&highlight=
  10. Thanks Instigator thanked for this post
    Likes Instigator liked this post
  11. #550
    Oct 2005
    savannah,ga
    That was a good test ,nothing bad happened!
    Also, that is a great color scheme.
  12. Likes Instigator liked this post
  13. #551
    Feb 2012
    Syracuse,NewYork
    Good for you Gary. You have a lot to be thankful for....God bless
  14. Thanks Instigator thanked for this post
  15. #552
    It’s alive!
    Splashed it today.
    It did not.
    Yah!
    Ya 45° is not the best time to tune, you and the motors are cold. Never doubted the bracket, you had that.
  16. Thanks Instigator thanked for this post
  17. #553
    Jul 2004
    Connecticut
    Agree, you got it over the goal line. Now time to put her away and take a rest.
  18. Thanks Instigator thanked for this post
  19. #554
    Calgary, Alberta
    Good job Gary ! And I'm jealous of still having a boat in the water in late November lol. Our water is a "a little solid" right now
    Matt
  20. Likes Instigator liked this post
  21. #555
    7 Post(s)
    I really want to make a few changes and head back today but......
    Matt, our water will be hard very soon.
    A. Today will probably be our last, decent weather day and I just started the railings on my deck from hell.
    B. My wife Cheryl let me buy myself an early Christmas present while visiting “Lake Trash”, my Coon Ass brother in Shreveport last week and it just got here.
    It needs a bath and is WAAAAAAAAAYYYYYY more fun than anticipated ��
    Bought his ‘02 Trans Am that was built by Gene Deputy of Texas Turbo fame and it is a wicked bitch!
    Has Ls6/Z06 based motor w/a stroker crank, CNC heads, basically the best of everything and set up and tuned perfect!
    And w/411 gears it will blow off its 275 tires from a 40 mph roll in 3rd gear!
    And w/a 6 speed manual it turns 1500 R’s @ 60 in 6th gear!
    Came w/a complete history in two manilla folders.
    And rect’s for three sets of rear tires ��
    An amazing piece.
    Mr Trash went 11.70’s @ 117 in it!
    Ironic that when I sold my ‘68 440 six pack Super Bee 15 yrs ago, I told all of my friends in disbelief that w/what I got for the Bee, I could buy a 10 yr old Stang, put a blue bottle in the trunk and do everything the Bee did but have power seats, AC, cruise etc, for the same money.
    Other than not being a Stang, I just did it.
    Attached Thumbnails Attached Thumbnails 9E7DE48B-3D42-43A9-9EA9-9A45A5300051.jpg   0EA08444-0923-4978-B6EA-E3FF057292B9.jpg
  22. Likes rgsauger liked this post
  1. 1977 checkmate convincor
    By faztbullet in forum Ebay Listings and Other Internet Listings
    Last Post: 06-24-2016, 06:24 AM
  2. Just got in a new Checkmate 28 OBX twin outboard
    By WILDMAN in forum General Boating Discussion
    Last Post: 06-13-2011, 08:16 PM
  3. checkmate 242 checkmate convincor
    By Mastercraft241 in forum Posting Questions and Suggestions
    Last Post: 05-25-2006, 09:43 PM
