Page 35 of 51 FirstFirst ... 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 LastLast
Results 511 to 525 of 764
  1. #511
    7 Post(s)
    They still have some vee to them.
    Ny plans is for a 5 1/2” flat pad added to it.
    I always thought the old Convincer 25's had raised pads from the factory.
    Attached Thumbnails Attached Thumbnails DD4C901E-0E30-44DB-834A-5A7DE11EB176.jpg
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  2. Likes sonicss33 liked this post
  3. #512
    Mar 2002
    N.E. Ohio
    Just to make mrichartz happy , Pulled the trailer out from under the boat to weight so I can then weight it w/the boat to see where we’re at.
    No sure if I can “not” put a pad on the bottom now 
    now there’s the rational I like to hear
    Mirage Jaguar RiverRacer
    Polaris PRO785
    Bennington 255LCC
    Scream & Fly Flying Machine of the Month:
    September 2005
    http://www.screamandfly.com/showthre...ild&highlight=
  4. #513
    Jul 2004
    Connecticut
    They still have some vee to them. My plan is for a 5 1/2” flat pad added to it.
    Got it.
  5. #514
    You should be able to get it up on that v pad. Try it first could have some adverse effects on handling all round. Sometimes a bit od compromise is the best.
  6. #515
    7 Post(s)
    I have no doubt about getting it to, and keeping it on the pad.
    I have a combined 14 yrs on two 24’ Sonics and keeping them on their pads, and they were round ��
    Only fast pad is a flat pad.
    Quote Originally Posted by Dave Strong View Post
  7. Likes Dave Strong liked this post
  8. #516
    Aug 2010
    Barrie, Ontario, Canada
    Why does the lip of the pad look a little wonky on the left side? I am sure it must just be the angle of the pic?
    Triad V21 #002 - 15in DBR 300 xs
    19' J-Craft - 175 Opti
    18' Pontoon - 115 CT 4S
  9. Likes Instigator liked this post
  10. #517
    7 Post(s)
    It’s primer showing through the white gel coat I burned through when buffing the transom before installing the bracket.
    Doh!
    Quote Originally Posted by V-bottom View Post
  11. #518
    Aug 2010
    Doh!
    Well at least that's an easy fix.
    When is the 1st launch expected?
  12. #519
    7 Post(s)
    No clue.
    W/the pool/deck project going on, my free time is spread a bit thin these days.
    Ive done enough of these projects to know that if you stop at 80% and start using/running it, you never finish it.
    Ive wanted one of these all my life so if it takes another yr....., I’m OK w/that.
    I had my deck helper help me carry in my patio door/mold to start laying up the pad for the bottom.
    Attached Thumbnails Attached Thumbnails 510C1E88-D6B3-4966-A4FB-60F6A004D4F1.jpg
  13. Likes mrichartz liked this post
  14. #520
    Jul 2005
    AZ
    Yea if you take it out you all of a sudden you over look or it's good for now then it's years later..
    It's coming along nicely..but another year I can't wait that long get it together man.! Lol
    '84 Checkmate Convincor
  15. Thanks Instigator thanked for this post
  16. #521
    7 Post(s)
    I know, I know.
    I didn’t have the supplies I needed to lay up the pad on the door so after scratching my head a bit and not wanting to waste a rain day, (BTW, tomorrow is one too) I built a mold.
    If my thinking is clear and my math is close, should be a pc of cake.
    Mold is 8’ and spit balling is looking like 11’ - 12’ overall which is way shorter than I thought.
    Ill start laying it up tomorrow.
    Attached Thumbnails Attached Thumbnails DB08BD33-AE83-4719-95D9-9DA6DD5451BE.jpg
  17. Likes Dave Strong, MODVP22, mrichartz, tnelsmn liked this post
  18. #522
    7 Post(s)
    Slow progress, but progress just the same.
    Spent the last 3 months building the boss a pool and deck from hell.
    Got it enough finished to be functional then snuck out in the shop.
    After seeing a paper towel blow under a foot on one of my boat stands (meaning it’s on 3 feet instead of all four) I’ve decided to postpone the pad project.
    Steering at the motors has been apart and back together a bazillion Times But think I finally got it.
    Out of money due to the pool/deck project so being careful w/funds too.
    Got my control cables and adapters to put that together.
    Ordered battery cable to make them.
    Decided to update the trailer while the boat was off of it.
    Orig discs on front axle were toast so had to replace those calipers and cut the rotors.
    While at it I added a second set to the rear axle.
    Also added a second set of bunks. Only had two orig and I didn’t like what I saw.
    Founf the switches I needed to put trim in the throttle handle.
    Fall is here in Ohio but still hoping to get it wet before our water gets hard.
    Heres some random pixs.
    Attached Thumbnails Attached Thumbnails 3C4F0E2A-42EE-47EA-B075-8A34CE410D26.jpg   9D9B6FE6-B617-4FF3-81BA-D1C718BD5A4A.jpg
  19. #523
    Aug 2020
    Dallas
    Do you spray your gel in the shop? If so, what kind of spray setup do you use?
  20. #524
    7 Post(s)
    Used MEK and thinned it enough to blow through a regular HVLP fun.
    Only issue was it flowed tacked up w/a gloss then dried to a flat finish.
    Was hoping to skip the buff/polish process.
    Quote Originally Posted by Pilotryan View Post
  21. #525
    Your not gonna run it and have a before and after pad comparison?
    Actually if it was mine it would never go back under the knife once it runs so it wouldnt get a pad once it runs.
  22. Likes Instigator, SCT liked this post
  1. 1977 checkmate convincor
    By faztbullet in forum Ebay Listings and Other Internet Listings
    Last Post: 06-24-2016, 06:24 AM
  2. Just got in a new Checkmate 28 OBX twin outboard
    By WILDMAN in forum General Boating Discussion
    Last Post: 06-13-2011, 08:16 PM
  3. checkmate 242 checkmate convincor
    By Mastercraft241 in forum Posting Questions and Suggestions
    Last Post: 05-25-2006, 09:43 PM
