Results 1 to 14 of 14
Thread: 95 Mercury 125hp 4 cyl Help
01-07-2018, 11:55 PM #1
I have a 4cyl 125hp, motor is popping when idling, like a small backfire, all electrical checks out fine, when I cover no#3 carb and block off air motor smooths out and runs fine, checked reeds and cage, looks good, any ideas???? I'm stumped now!
BLAZER BAY 2400 SUZUKI 250 4 STROKE
18FT ASTRO BASS BOAT 200 MERC
01-08-2018, 07:53 AM #25000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
01-08-2018, 09:11 AM #3
Dam why didn't I think of that!!!!!! I'll check tonight.
01-08-2018, 11:25 PM #4
looks like all butterflies are closed
01-08-2018, 11:52 PM #55000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
had one w/#3 needle/seat for accelerator pump stuck open.pinch off hoses going to #3-#4 cylinders.run at nite/under cover to locate cyl with coughing problem-have to remove electrical plate to get to n/seat valves-th
01-09-2018, 09:24 AM #65000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
01-09-2018, 10:11 AM #7
I will check valves and take carb apart , thanks guys stay tuned.
01-09-2018, 11:01 AM #8
Many years ago my Merc 115 ad the same issue and I eventually found that the 2 brass check valves in the recirc system were dirty. Took them apart, cleaned them and stretched the spring just a whisker, put them back together and made all the difference in the world. Had another motor come into the shop doing the same thing and doing this cleared up that motor too. I believe the later models did away with the cleanable brass check valves.
Hustler 15' Wildcat / Merc 80
Hustler 13' Wildcat / Merc 80
Hustler 13' Picklefork (Experimental) / Merc 80
Hustler 16' Victor / Evinrude 85
Hustler 15' Tunnel / Evinrude X115
Hustler 17' Lark / Suzuki 140
Ranger 17' Aztec / Merc 115
Hustler 16' Victor
Hustler 16' Victor / JohnRude 135 (current and restored)
Hustler 15' Family Tunnel / Johnson GT115 (current project)
Hustler 16' Victor
01-09-2018, 11:13 AM #9
Just to clarify...the check valves I'm talking about thread into the block and the electrical plate needs to be unbolted and moved out of the way enough to get at them.
Hustler 16' Victor
Hustler 16' Victor
01-09-2018, 11:40 PM #10
Ill check them on Wednesday so they should only blow one way I'm guessing, are they cleanable with some brake clean or should I just order new ones.
01-10-2018, 12:12 AM #11
If I remember correctly it's a needle/seat assy...don't remember if it was a brass seat and a rubber tipped needle or stainless needle. I just removed the whole assy, disassembled, cleaned with carb and choke cleaner, stretched the spring just a little, blew dry with compressed air, reassembled and reinstalled. Pretty straight forward. After you clean them put a little sealant on the threads before reinstalling.
Hustler 16' Victor
Hustler 16' Victor
01-10-2018, 11:43 PM #12
Yep little brass fitting, it actually has a carb needle and spring in it, I didn't get a chance to fire it up , ill do that Thursday. Hope this does it. Tiny little hole spraying in the cylinder??????
01-11-2018, 12:07 AM #13
You cleaned them both right? One about mid block and the other a little lower. Not sure what the reasoning is...all I know is that crap must be holding the needle open causing some sort of a lean condition in the recirc system. Also...like the others have said do a good link and sync,all carb butterflies closed at dead idle and low speed needles adjusted correctly.
Hustler 16' Victor
Hustler 16' Victor
01-11-2018, 01:22 PM #14
Well after cleaning both needles and replacing the tiny fuel line, motors running awesome no popping, thank you all for you help, much appreciated!!!!!!!
my manual says start with idle screws at 1 1/2 turns out, seems to be ok there , I need to put it in the water and check timing hard to do it on a hose, thanks againBLAZER BAY 2400 SUZUKI 250 4 STROKE
DanUmbarger liked this post
95 Mercury 125hp Electrical Parts
By skatermike24 in forum Parts WantedReplies: 3Last Post: 01-17-2018, 04:37 PM -
Need to pick your brains, 99 125hp Mercury
By dpf-01 in forum General Boating DiscussionReplies: 8Last Post: 09-29-2013, 05:12 PM -
125hp Mercury on a 15' center console Yes or No.
By Gators27606 in forum General Boating DiscussionReplies: 1Last Post: 07-15-2012, 10:44 PM
