Results 1 to 6 of 6
01-05-2018, 07:26 PM #15000 RPM
- Oct 2015
- Kentucky lake
- 480
- 31
- 15
- 60
Wat brand rings to run in a merc 2.0 standard bore
I've got a merc 2.0 that I'm fix up.. Wanting to hone and re ring wat brand rings should I run.. and maybe where to buy from.. stock pistons and standard bore is wat I've got thanks
01-05-2018, 08:40 PM #2
Just get them from ProMarine
'95 STV "The Blue Goose"
01-05-2018, 10:38 PM #3
Make sure "mike" the cylinders as these wear at a taper....
01-06-2018, 09:16 AM #45000 RPM
- Oct 2015
- Kentucky lake
- 480
- 31
- 15
- 60
Ok thanks I'm Goin need to look closer to old rings as well merc book says...some upper and lower ring were different too.. top .093 tapered.. lower ring .063 with rectangular angle the other option was both rings .093 tapered , piston to match with .100 ring slots
01-06-2018, 03:06 PM #55000 RPM
- Oct 2015
- Kentucky lake
- 480
- 31
- 15
- 60
01-06-2018, 03:59 PM #65000 RPM
- Oct 2015
- Kentucky lake
- 480
- 31
- 15
- 60
Standard bore merc piston new or used
By 2.5-21 in forum Parts WantedReplies: 0Last Post: 12-10-2013, 10:07 PM -
Set of 12 brand new wizard rings for steel bore motor
By Billy Sedman in forum Misc. Parts and AccessoriesReplies: 3Last Post: 10-06-2013, 09:14 AM
