Results 16 to 21 of 21
01-07-2018, 11:12 AM #16
fuel pump sends it straight through, only pump the rubber fuel bulb as per normal, you will hear it going into the carbs, then bulb will go hard .
NeedOne thanked for this post
01-08-2018, 01:39 AM #17Team Member
- May 2009
- 1,875
- 557
- 76
- 636
- 301
- 6 Post(s)
Tygon is so soft and easy to work with and being clear is nice for diagnosing air leaks and such. It's obviously not nearly as durable as proper fuel hose... My question. IF you did use Tygon for inside the cowl fuel lines, how long could we expect it to last? 10 hours? 100 hours? Something in between? I'm tempted to try it on one of my motors just to see.
-Peter"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
and a handful of clunkers
01-08-2018, 02:15 AM #18Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
pressurised non reinforced hose???
01-09-2018, 11:36 PM #19
You can, but sometimes its tricky. You need to make a clean cut. There is usually a white liner in it. If you try to stretch it over a larger barb, the liner will roll backwards into the fuel flow passage. Its for high pressure so if it says its for 3/16" it don't really like to go on 1/4". If your always removing and installing the same hose, the liner gets loose at the very end. Its fantastic stuff, but as far as for me. Its not the greatest for a lot of removals. I pull hoses all the time, if it were a once a year hose pulling job, Id probably buy it. But not with my stuff.
01-11-2018, 12:56 AM #20Team Member
- May 2009
- 1,875
- 557
- 76
- 636
- 301
- 6 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
01-11-2018, 04:21 AM #21Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
Mercury Tech: Fuel rails for carb motors
By 90 5.0 in forum Technical DiscussionReplies: 11Last Post: 04-04-2017, 03:28 PM -
Mercury Tech: V200 Carb Lines? Rusted on fuel sender cap....
By mwidden in forum Technical DiscussionReplies: 3Last Post: 03-12-2015, 08:02 AM -
What fuel pressure for 200 carb motors?
By WATERWINGS in forum Technical DiscussionReplies: 4Last Post: 01-11-2006, 05:54 PM
