Results 16 to 22 of 22
12-31-2017, 09:06 PM #16Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Most any thing can be fixed......is it worth fixing?... Drill hole tap and Good bolt. Don't know if the crank is too hard for that.
01-01-2018, 09:42 AM #17
Problem now is how much more damage will be done just to get the flywheel off?
01-01-2018, 10:55 AM #18
01-01-2018, 11:12 AM #19
Yeah maybe so,but man he must have had some serious torque on that snap-on puller to that much damage and to not know he was doing it ?
01-01-2018, 01:28 PM #205000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
01-01-2018, 01:39 PM #21
Im thinkin motor needs a rebuild? or a bad crank bearing ?
01-02-2018, 11:58 PM #22
As chaz said see whats there once u get the wheel off.. doesn't merc use that big like .200 thick washer under the nut? may have enough threads to put a low profile aircraft 12 point nut on with a thinner washer orrr....wouldn't be that big of a deal for a good machinist to cut it off bore and thread it for a fine thread hard 12 point bolt, would be no different than the drive end of most 2 stroke jet ski and snowmobile engines with internal threads on the taper. But.... probably easier to find a used one since u have to pull it apart to fix it anyway. Dave
Mercury 3 liter crankshaft
By Phil Conant in forum Misc. Parts and AccessoriesReplies: 0Last Post: 09-19-2017, 01:01 PM -
By Phil Conant in forum Misc. Parts and AccessoriesReplies: 0Last Post: 09-19-2017, 12:56 PM -
Yamaha 3.1 liter crankshaft assembly
By M.CHAPMAN in forum Misc. Parts and AccessoriesReplies: 0Last Post: 10-02-2014, 12:55 PM -
Will a 2.0 merc crankshaft work in a 2.4 liter?
By 370VRanger in forum Technical DiscussionReplies: 7Last Post: 12-03-2008, 08:45 AM
