Results 31 to 45 of 45
12-25-2017, 03:03 AM #31Member
- Sep 2017
- California
- 37
Thanks Guys I will give it a go tomorrow without the lines connected to the big tank. And premix planning on pouring out the gas on the on board water fuel separator and priming back with fresh pre mix. Will the pre mix be a problem goin through this filter? I’m thinking it should be fine but just askin to be sure once again thanks to everyone and have a Merry Christmas
12-25-2017, 09:05 AM #32
filter is fine with premix
12-25-2017, 09:08 AM #33
Also, mark the reservoir at the oil level and let the motor run about 15 - 20 minutes and check the level again to see if the oil system is working.
12-30-2017, 01:04 AM #34
simple answer.... drive it to someone qualified
12-30-2017, 04:43 PM #35Member
- Sep 2017
- California
- 37
Capt.Insane-o liked this post
12-30-2017, 04:58 PM #36Member
- Sep 2017
- California
- 37
12-30-2017, 05:03 PM #37Member
- Sep 2017
- California
- 37
12-30-2017, 06:59 PM #38
Put a new needle in the vst too
12-30-2017, 10:59 PM #39Member
- Sep 2017
- California
- 37
Capt Insane-O thanks so much appreciate the heads up.Especially the Fuel pump! There local for me out here in CA so I’m able to drive and pick it up. Vst tank cleaned up well have most of the crud gone. Which has me concerned about the fitting for the oil mixture line. Exactly how does it work? I mean when gas is inside of the vst no gas leaks out. So I’m thinking it’s clogged from the crud,although I don’t see any crud in the fitting. Some light shined on this matter would be great
12-30-2017, 11:15 PM #40
It has a spring loaded check valve in it to keep the oil from filling the vst. Judging by the build up I'd carefully clean or replace it.
endurance thanked for this post
12-31-2017, 04:49 PM #41Member
- Sep 2017
- California
- 37
Thanks I just been letting it soak. Thinking more on the lines of replacing
12-31-2017, 04:57 PM #42
Some people ask why do you drain the VST for storage? Your pic is a perfect example.
01-01-2018, 06:45 PM #43
01-01-2018, 07:29 PM #44Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
For some reason all of my old 3.0 EFI'S have had the hose from the top bearing to the bottom crank case fitting go bad first. Way before the others. May be heat related? Or, because it's the hardest one to get to? Ha ha
03-12-2018, 11:01 AM #456000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
15 ft steering cable marina @178$ on line disc mar supp 102$ 2 DAY free ship! gotta shop for sure.
GT-150 in the water after sitting over 20 years
By gregpro50 in forum General Boating DiscussionReplies: 32Last Post: 06-21-2013, 10:00 AM -
mercury 250 efi starting after sitting
By speedthriller in forum Technical DiscussionReplies: 3Last Post: 08-14-2011, 06:56 PM -
Evinrude sitting for years
By tracktech in forum Technical DiscussionReplies: 11Last Post: 08-25-2008, 06:06 PM -
Starting a motor that's been sitting for years
By gbourdon in forum Technical DiscussionReplies: 3Last Post: 08-20-2008, 04:25 PM -
2.5 EFI been sitting 2 years...
By yanny_haulinbass in forum Technical DiscussionReplies: 7Last Post: 04-18-2006, 09:19 AM
