Results 1 to 15 of 21
    Jan 2017
    Australia
    Top guided rods / bottom guided pistons
    I bought a rebuild kit for my Merc 2.4l - 200 86. The boss on the new pistons is wider than on the old pistons. So the rod and rollers can move around.
    Did some research and it appears my old pistons are made for bottom guided rods. Looks like I have top guided rods.
    So can I convert to top guided just by adding washers so there is no slop or do I need new pistons (or rods).
    Sep 2015
    Twin Cities, Minnesota
    This might be what your looking for. This is from my 2.5 but I think its the exact same. Then again, maybe not.
    Attached Thumbnails Attached Thumbnails 20170327_191730.jpg   20170327_191703.jpg
  3. Thanks Steve200 thanked for this post
    Who's kit is it?
    TX......somewhere?
    whats tha number on tha rods?...number on tha pistons?
    Merc never made a top guided 2.4. The piston should be loose on the rod.
  7. Likes 90 5.0 liked this post
    Aug 2009
    mpls,mn
    yep im rebuilding one right now.
    May 2014
    Livingston, Louisiana
    Just make sure it has the right washers on the sides of the rod on wrist pin side. Bottom guided washers should be stepped like Krazy's. Would still be good idea to post number on rod to make sure it ain't been no swappin going on.
    Mar 2010
    houston, tx
    What about the 1-2 weird year 2.4’s that were sleeved 2.5’s in essence were anybof those top guided?
    TX......somewhere?
    bottom guided.. everything till '93 was bottom guided.. even tha 260......
  12. Likes 90 5.0 liked this post
    Jan 2017
    Australia
    Hey Guys thanks for the replies. It's a TSM rebuild kit, they said they had to modify it to suit the chrome bore 200 I have. It's the only kit I could find that suited it.
    The motor is next door (15 minutes away) on my neighbours bench. I'll get back up there over the weekend to find out more. Just has some minor surgery so am on my arse for a couple of days.
    It's an old motor and has been rebuild before so who knows what is in it.
  14. #11
    Jul 2013
    Many years ago I used to make thicker top guided washers for this type of application. Heat treated, hardened and ground. They worked great.
    Not sure if I still have any but I'll check. Won't be able to look until after the 1st.
    TX......somewhere?
    one mo time... whats tha number on tha rods???..... whats tha numbers on tha pistons???
  16. #13
    Aug 2009
    mpls,mn
    don't think he has the powerhead tore down yet?
  17. #14
    Jul 2013
    Quote Originally Posted by Onetime View Post
    After thinking about this more I'm changing my story. I made thicker spacers when the small top guided rods came out so I could still use pistons for big top guided rods with the small top guided rods.
    Sorry, it was a long time ago!
  18. #15
    Jan 2017
    Australia
    Quote Originally Posted by racervboat View Post
    Yeah as mentioned its up at my nieghbours house a 15 min drive away along the ridge. I'll get those part numbers this weekend.
    thx, cheers.
  1. Mercury Tech: Using top guided rods with bottom guided mahle 260 pistons, how to stack washers
    By Bruce C in forum Technical Discussion
    Last Post: 07-11-2017, 11:35 AM
  2. Top guided rods in bottom guided pistons.
    By MALCOLM MCGEHEE in forum Technical Discussion
    Last Post: 06-24-2010, 12:56 PM
  3. Top guided vs bottom guided rods for 2.4
    By coffeeguy in forum Technical Discussion
    Last Post: 04-26-2009, 11:35 PM
