Results 1 to 4 of 4
    Oct 2012
    Annapolis, MD
    Completely Brand New Blown Dart 540, 10-71 Blower Shop Blower, 1150 HP, Best Parts
ID:	394869Click image for larger version.
ID:	394870Click image for larger version.
ID:	394871Click image for larger version.
ID:	394872Click image for larger version.
ID:	394873Click image for larger version.
ID:	394874Click image for larger version.
ID:	394875Click image for larger version.
ID:	394876Click image for larger version.
ID:	394877Click image for larger version.
    Completely Brand New Blown Dart 540 with a 10-71 Blower Shop Blower.
    Built with the best of everything.
    Total build cost: $28,601.59 / Asking $26,500.00
    1150 HP Initial start and break in time only
    Ready to drop into your boat and go
    Will meet and load engine for shipping Please ask any questions.
    Please call and leave a message if I don't pick up. 301-751-8024
    Located in Easton, MD 21601
    Complete Build List: Dart BIG-M Standard Deck Block - $2,632.58
    Callies Magnum Crankshaft BBP42B-MG – $2,056.00
    Crank Balancing - $ 135.00
    Oliver Big Block Chevy MAX Rods – $1349.99
    JE Pistons (257942) – $809.67
    Canton BBC HIGH CAPACITY MARINE PAN – $649.00
    Melling High Volume Oil Pump – 149.01
    Felpro Oil Pan Gasket (FEL1884R) - $39.99
    Dura-Bond GMP-2T Cam Bearings - $66.97
    Clevite Main Bearings – 145.97
    Clevite Rod Bearings – 129.90
    Howards Custom Grind Cam - $431.56
    Cometic Head Gaskets – 199.60
    Dart Pro 1 Heads 355cc – $3377.14
    Ferrera Severe Duty Valves – $151.92
    Inconel Valves – $399.28
    PAC Valve Springs, Titanium Retainers, Locks – $582.00
    Comp Hi-Tech .80 Pushrods – 161.87
    Crower Lifters W/ HIPO Oiling – 779.97
    T&D Machine Products, Competition Shaft Rockers - $1626.00
    The Blower Shop 10-71 Blower, Manifold, Belt, Idler, Pulley – $5199.99
    The Blower shop Dual Carburetor Flame Arrestor – 595.00
    The Blower Shop Dual throttle Linkage Kit – 130.00
    The Blower Shop Stainless Fuel Lines – 290.00
    Dual QFT Quick Fuel Technology 950 Marine Coated Carburators – 1946.00
    Supercharger Water Outlet 1" Slip-on Divider W/ Bypass – $115.99
    Standard 1-1/4" Slip-On Port Entry Stainless Steel Water Inlet Crossover - $148.99
    Billet Aluminum 8MM Supercharger Pulley - $111.00
    ATI Super Damper Supercharged Series Harmonic Balancer 917060K - $372.97
    ATI Adjustable Timing pointer 918958 - $43.00
    Sealed Power Hellfire Moly Piston Rings – 166.97
    Block hone, Bore & Balance - $ 759.00
    ARP Flywheel, Stub Kit & Main Stud Kit - $337.78
    ARP Engine Bolt Kit – $163.02
    Block Surfacing – $198.00
    Moroso 23782 Oil Filter Adapter Replacement O-Rings - $61.81
    CVR Pro Torque Starter – 278.97
    CVR Fuel Pump Block Off Plate – $19.97
    Cloyes Gear (9-3100B) timing Set – $178.97
    IMCO New Style Valve Covers - $388.00
    Big Block Chevy Polished Aluminum Timing Cover - $69.99
    Felpro Valve Cover Gaskets – 35.99
    Taylor Spiro-Pro Spark Plug Wire Set – $58.97
    Mercury / GM internally balanced 168 Tooth Flywheel – 395.99
    MSD Distributor – $331.95
    MSD 6AL Ignition box - $254.95
    MSD Blaster 2 Coil - $48.91
    Felpro Header Gaskets – $25.99
    Total build cost: ($28,601.59)
    Block Mains Crank Mains 1) 2.751 1) 2.747 2) 2.751 2) 2.747 3) 2.751 3) 2.747 4) 2.751 4) 2.747 5) 2.750 5) 2.747
    Rods Crank 1) 2.2015 1) 2.199 2) 2.2015 #2) 2.199 3) 2.2015 3) 2.199 4) 2.2015 4) 2.199 5) 2.2015 5) 2.199 6) 2.2015 6) 2.199 7) 2.2015 7) 2.199 8) 2.2015 8) 2.199
    Ring Gap Top - .022 2nd - .024 Crank Thrust - .0055 Piston to Wall - .0055 Bore - 4.501 Pistons - 4.4955 Rod side clearance - .022 Deck height - .006
    Howards Cams Running Clearance Intake - .024 Valve Lift - .672 Running Clearance Exhaust -.024 Valve Lift - .672 Lobe Center - 114T4 Profile - 6141 Part 29999 Gross Lift at Cam Degree of Duration .050 Intake .395 Intake 252 Exhaust .395 Exhaust 262
  2. Likes Frank Molé liked this post
    Oct 2012
    Annapolis, MD
    New lower price: $26,500.00
    Oct 2012
    Annapolis, MD
    Bump..
    Oct 2012
    Annapolis, MD
    New lower price: $25,500.00
  1. V6 Omc Blower Project
    By madman in forum Technical Discussion
    Last Post: 10-05-2008, 05:13 AM
  2. Blower/Supercharger??
    By advjet in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 09-02-2008, 02:29 PM
  3. New Blower Motor is Done!
    By johnnyoffshore in forum General Boating Discussion
    Last Post: 07-21-2007, 07:21 AM
  4. Blower On V6 Omc
    By madman in forum General Boating Discussion
    Last Post: 12-25-2003, 10:25 AM
