Results 1 to 5 of 5
Thread: 2002 evinrude 250 DI rpm range
12-13-2017, 11:00 AM #1
I was wondering where do I want the RPMs at WOT loaded for fishing. I always thought
5800 was good. I was told they need to be on the 6k limiter is that right?
12-13-2017, 11:43 AM #2
They add fuel at 5800 (soft limiter) I have scuffed a piston above 5800 on a long run. Don't know if they add oil as well or just fuel. Peak power is at 5500.
12-13-2017, 11:49 AM #3
I thought these motors run 5500-6000 RPMs. I thought the soft limiter was 6k
12-13-2017, 02:05 PM #4Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
They add fuel starting at 5800 with soft limit at 6100. I always set them up to run 6000 light load so they run 56 to 58 with a load.
12-13-2017, 02:20 PM #5
So where should I prop it to run WOT 6000rpms? most of the time
it will be just me and a full tank 70 gal and fishing gearLast edited by jimmyz32; 12-13-2017 at 02:27 PM.
79' 235 Evinrude, Best prop for hole shot and mid range pull.
By HotRodV6 in forum Props, Setup, and RiggingReplies: 5Last Post: 03-13-2014, 12:06 AM -
2002 250hp evinrude fitch
By bciii in forum Technical DiscussionReplies: 1Last Post: 09-18-2012, 09:51 AM -
OMC Tech: 2002 Evinrude 250 DFI
By Greg G in forum Technical DiscussionReplies: 32Last Post: 07-09-2012, 10:05 AM -
2002 Evinrude 250 Questions
By Greg G in forum Technical DiscussionReplies: 5Last Post: 12-04-2009, 09:08 AM -
OMC Tech: 2002 225 Evinrude Ficht problem
By Tuna Sniffer in forum Technical DiscussionReplies: 5Last Post: 08-20-2009, 09:23 PM
