Results 1 to 10 of 10
Thread: Prop selection questions
12-12-2017, 04:21 PM #1
I have a 1994 21' seacraft copy weight is 1,500lbs with a 2002 evinrude DI 250. So far I have run 4 props all on the revlimiter. The only one that wasn't on the limiter was a 30p raker. The boat ran 4200rpms trimmed out and WOT. I like the way the raker runs so I was thinking of getting a 22 raker and having it built or getting a 24p raker or a 21p rev4. I think the 24 raker would be right in the middle of my 5500-6000 power range. If y'all come up with a different idea please help me out. Thanks
12-12-2017, 06:23 PM #25000 RPM
- Oct 2017
- Hugo, MN
- 326
- 36
- 18
- 62
- 81
What pitch were the props you were running against the limiter?
Also, I’m pretty sure running your motor WOT at 4200 is pretty hard on the motor. That 30 is way too much prop. On the other hand I fear going all the way down to 22 is going to be too little and back against the limiter.
I’m no expert though.
12-12-2017, 06:29 PM #3
I started with the one that was on the motor. 16p SST, then a 18p Rebel, then a 19p trophy plus, then a 21p trophy plus in bad shape. All where on the limiter.
12-12-2017, 07:26 PM #4
I have a 24 Raker I want to sell.
18 Action 225 Promax
12-12-2017, 07:31 PM #5
I have an eye on your 24 if that is the proper direction for me
12-12-2017, 08:54 PM #6
12-12-2017, 09:28 PM #75000 RPM
- Jan 2004
- lindsay on. canada
- 370
- 14
- 13
- 68
- 34
RK has made you a good offer , you want that motor at 6000 wide open or a little more 6200/6300 . when the heat of the summer comes back you want it to be in the operating range near the upper limit . That motor does not like to lug ........
12-13-2017, 07:21 AM #8
Text me picks of the prop. 8134777109
12-13-2017, 10:52 AM #9
Thanks re for the prop. Frank Jackson you said these motors like to run at the 6k limiter?
12-13-2017, 05:38 PM #105000 RPM
- Jan 2004
- 370
- 14
- 13
- 68
- 34
Over is better than lugging
Some questions about material selection
By Slimm in forum Fiberglass and Composites DiscussionReplies: 16Last Post: 09-22-2015, 12:39 PM -
prop selection for a voo-doo with 60 omc? help please
By voodoorye in forum Technical DiscussionReplies: 2Last Post: 02-06-2008, 11:41 PM -
Prop selection questions...
By Steve2ManyBoats in forum Technical DiscussionReplies: 0Last Post: 08-16-2007, 10:57 AM -
prop selection???
By talon in forum Props, Setup, and RiggingReplies: 2Last Post: 06-25-2004, 06:29 PM -
Prop selection for a T/H
By Xallison in forum Technical DiscussionReplies: 4Last Post: 12-09-2003, 12:32 PM
