Results 1 to 7 of 7
Thread: Mercury 2.5 200 hp Lower unit
12-11-2017, 10:22 PM #15000 RPM
- May 2017
- US / NC
- 131
Think this motor is around 1990 Mercury carb . 2.5 200 hp with a standard 1.87 ratio lower unit .
What is the correct procedure to pressure test this foot . How many pounds @ diff. setting and how long should it hold pressure @ each reading .
I think you check 3 place's .....prop shaft / drive shaft / and gear shaft seal ?
Thx for any help .
12-13-2017, 01:20 AM #25000 RPM
- May 2017
- US / NC
- 131
TTT No one know the spec's of air pressure that you need to use to pressure the lower unit .
From a another forum , a member said he does 10 psi on his sport master , but did know on a standard lower unit .?
12-13-2017, 02:24 AM #3
10-12 pounds. Too much and it will blow past the shift shaft seal first.
12-13-2017, 08:47 AM #4The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
You can also do 6 pounds. As long as there is no leakdown. Thats what you need to see.
12-13-2017, 11:35 AM #55000 RPM
- May 2017
- US / NC
- 131
Thx 6 - 10 pound's is in order .
12-13-2017, 02:22 PM #6
It is more important to test under vacuum. The normal failure mode is with water being sucked in when the case cools after being run and vacuum testing checks those seals. I use a brake vacuum fill pump and pull 15" for 15 minutes. A good case will drop less than 1", Most dont drop at all.
Go Time
26 Regulator twin 250 EFI
12-13-2017, 08:30 PM #75000 RPM
- May 2017
- US / NC
- 131
Thx Go Time
Had one on order to do the brake's on the trailer . Just came in the mail before i headed out to work .
mercury quicksilver lower unit vs tourqmaster lower unit
By jshotts in forum General Boating DiscussionReplies: 3Last Post: 01-26-2015, 01:23 PM -
Lower unit help 2007 115hp mercury can not find neutral,reverse with lower off
By pinetar in forum Technical DiscussionReplies: 0Last Post: 07-15-2014, 02:50 PM
