Results 1 to 3 of 3
Thread: Overheat Alarm Test
12-09-2017, 09:52 AM #1
Overheat Alarm Test
Is there a quick and easy way to test the overheat alarm on a Merc? I just want to be sure it's working.
Can I unplug the beige wire with the blue stripe at the butt connector, ground it and see if I get a beep? Or will that screw something up? Or is there a better way? Don't want to fry anything as the engine runs perfect.
Assuming the key must be on and the lanyard connected...
2001 15' Stumpnocker 5 (deep v)
2005 Mercury 60
specboatops liked this post
12-09-2017, 12:03 PM #25000 RPM
- Mar 2004
- vonore tn.
- 225
- 21
- 28
yes that is correct, with key switch on, simply touch tan w/ blue stripe wire to ground. that should sound warning horn.
litespeed, specboatops liked this post
12-09-2017, 12:49 PM #3
Thanks! Just checked it. Works great.
2005 Mercury 60
XRI overheat alarm
By LAPLANT in forum Electronics, Audio Systems, and WiringReplies: 0Last Post: 04-10-2008, 05:09 AM -
'95 Mariner Magnum 200 - oil injection removed now overheat alarm test
By alabass in forum Technical DiscussionReplies: 0Last Post: 02-17-2008, 10:02 PM -
Proper procedure to test overheat alarm on 2005 Merc 150??
By Ron V in forum Technical DiscussionReplies: 2Last Post: 06-04-2005, 09:15 PM -
225 Pm Overheat Alarm
By sprig in forum Technical DiscussionReplies: 3Last Post: 06-24-2004, 07:13 AM -
Overheat alarm tip....
By Superdave in forum Technical DiscussionReplies: 4Last Post: 07-26-2003, 10:09 AM
