Results 1 to 6 of 6
    Oct 2016
    Long Island, NY
    Trim/Tilt leaking down overnight
    08' 250xs Opti. Trim/Tilt leaks down overnight. I leave the motor trimmed up just a tad and the next morning the skeg is touching the ground. No visible leaks, pump and fluid reservoir are mounted in the boat and look OK. Do I need to repair this, and will it get worse if I don't? What's involved? Thanks.
    Jan 2010
    Rotorua, NZ
    valves in the pump might have a slight leak, but overnight I guess you could expect a slight leak like that in a 10 y/o pump? Before you go pulling things apart I'd replace all the fluid with the correct stuff - could be some wrong viscosity stuff in there maybe, or condensation/gunk etc. Easy and cheap to try at least!
  3. Thanks bouyhead thanked for this post
    Sep 2016
    McHenry,Illinois
    Don't know a lot about the Opti's but if it has a manual release valve try opening it and run the trim up and down to flush it out some then close it and try it again...if that doesn't work it could be a ram leaking internally or a leaking internal valve/check valve. Just a couple of ideas anyway.
    Hustler 15' Wildcat / Merc 80
    Hustler 13' Wildcat / Merc 80
    Hustler 13' Picklefork(Experimental) / Merc 80
    Hustler 16' Victor / Evinrude 85
    Hustler 15' Tunnel / Evinrude X115
    Hustler 17' Lark / Suzuki 140
    Hustler 16' Victor / Merc 125
    Hustler 16' Victor / Johnson 135 (current and restored)
    Hustler 15' Family Tunnel (future project)
  5. Thanks bouyhead thanked for this post
    try loosening the relief valve and then tighten it again, this sometimes does the trick.
    or try tilting the engine up a lot more so there is a bit more pressure on the seal and see if this makes a difference.
    how long as this been happening ?
  7. Thanks bouyhead thanked for this post
    Oct 2016
    Long Island, NY
    Quote Originally Posted by phillnjack View Post
    About 1-2 months ago, just when the weather cooled off.
    me and DanUmbarger was posting and thinking on the same lines at same time ha ha
    try what Dan says, its worth a shot before tearing into it.
  1. Trim and tilt leaking internally possibly?
    By 0081 in forum Technical Discussion
    Last Post: 10-13-2013, 10:46 PM
  2. Mercury Tech: tilt/trim cylinders leaking
    By ls7colorado in forum Technical Discussion
    Last Post: 06-07-2009, 05:37 PM
  3. Tilt Leaking Down
    By FOXCRAFT0923 in forum Technical Discussion
    Last Post: 08-16-2008, 09:48 PM
  4. OMC V4 tilt cylinder leaking at pigtail
    By Riverman in forum Technical Discussion
    Last Post: 07-11-2007, 07:39 AM
