Results 16 to 18 of 18
12-07-2017, 08:20 PM #165000 RPM
- Dec 2002
- jonesville, La
- 716
- 11
- 83
If it scuffed bad the plug should have aluminum on it
12-08-2017, 08:44 PM #17Member
- Mar 2004
- plaquemine La
- 36
- 18
- 57
If those gaskets were put on in the wrong order the impeller would have had to tear away that area of the gasket and pump it into the block. If this is the case, there are small holes in the exhaust plate & block that would not allow the gasket to pass. This is one of the main passages for the cooling system,& it will make the engine run hot very fast. You need to look at this if it is still running hot. This will cause your motor to fail. Next thing to look at is the rubber waterpump seals top & bottom To see if they are not pinched or cut from improper install. Just giving you some good advice & a place to start.
12-09-2017, 12:27 PM #185000 RPM
- Mar 2004
- vonore tn.
- 225
- 21
- 28
easiest way to check coolant water flow, and engine temp. remove motor hood, run on launch ramp, in gear. to 1,500 to 2,000 rpm. check pee stream, for water flow. you should be able to touch engine block with bare hand. your first reaction will be it,s too hot to touch. but it,s not, if normal.if it is too hot to touch it is over heating. touch sides of block near heads. do not get near spark plug wires.
Need expert mercury advice
By Magcat 62 in forum Technical DiscussionReplies: 6Last Post: 03-01-2015, 12:10 PM -
I'm new, I'm buy'in a boat, and I need your expert advice
By Collard Green in forum General Boating DiscussionReplies: 9Last Post: 01-09-2008, 11:00 AM -
Need Merc Expert Advice
By Scanos in forum Technical DiscussionReplies: 22Last Post: 08-12-2006, 10:34 PM -
Need a fishing Expert's advice here
By skatermike24 in forum General Boating DiscussionReplies: 12Last Post: 10-05-2004, 08:37 PM
