Results 16 to 30 of 34
Thread: Bearing carrier stuck bigtime
11-29-2017, 02:40 PM #16
Will probably here it pop over here on the east coast
11-29-2017, 03:00 PM #1796 Bullet 20cc, Yamaha OX 250+, 10" jack, labbed 30" Bravo LH w/1.25" exhaust pipes, counter rotating Bob's lower...it goes faster when you spin it the other way...
02 Dodge Cummins 2500 reg cab 4x4, converted long to short bed, up a foot, twins, injectors, fully built auto, dyno'd 582hp/1015tq
99 Dodge Viper GTS Coupe, 8.0L V-10, lowered 1", Corsa pipes/no cats, 450hp/500tq
11-29-2017, 04:01 PM #18
Take two bars of some flat stock, set them over the exhaust opening, put the prop on the shaft, put the thrust washer on top, screw the nut on and tighten it. It will come out. I assume this is a Merc case.
11-29-2017, 04:57 PM #19
Success!!! It's out! Thanks Capt.Insane-o! I can't believe how easy this method was...with no fancy tools whatsoever! Didn't even have to torque on the prop nut...it effortlessly walked it out! Pulled out the shaft and carrier together...I couldn't believe it! I kept adding flat stock to each side...used (3) 1/4" flat stock pieces total per side and had to keep adding a washers under the prop nut and used an old prop just in case...but it was ridiculously easy!
There were a bunch of good tips on this from everyone and I really appreciate everybody's help!
I took some pics while I was doing it...going to drink some now.Last edited by Bullet 20cc; 11-29-2017 at 04:59 PM.
noli liked this post
11-29-2017, 06:48 PM #20
that was a very good idea indeed, another very simple idea that works !!! brilliant , and glad it now out.
this is where plain old brute force and ignorance can beat a expensive tool .. Capt.Insane-o strikes again
11-29-2017, 07:03 PM #21Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Haha you said Force
11-29-2017, 07:39 PM #22
Right!? I still can't believe how easy it was. I'm sure I'll use your slide hammer advice on getting the drive shaft out. Found water intrusion at the seals under the water pump and some surface rust around the top of the pinion gear. And the drive shaft is siezed. Probably gonna put a piece of galvanized pipe over the shaft and weld a stop plate near the top of it and start smacking away. Pretty sure the drive shaft will be toast down low so already assume I'll need a new one. Everything else looks good inside...just gonna need bearings and seals and should be good to go...
11-30-2017, 02:32 AM #23
Nice! Can the propshaft come out on the merc or do you first have to do something? Put in neutral I guess?
11-30-2017, 07:31 AM #24
Something I should have mentioned, on the small ez shift Mercs pull the shift shaft out first, with cruisers and the 3 liter cases the carrier will only come out 1/2 to 3/4 of an inch or so until it bottoms out the clutch dog and the bell crank or case will break.
gfinch thanked for this postBullet 20cc liked this post
11-30-2017, 07:39 AM #25
Bullet,
Please continue this thread on parts replaced, lower unit fixes, etc...
very interested to learn how lowers are fixed.
Aaronhl thanked for this post
11-30-2017, 01:32 PM #26
Good point, this is a Yamaha case but also had to pull the shift shaft first since it pulled the entire shaft and carrier out as one very neat and tidy assembly...which was way better since the carrier/shaft assembly is way easier to separate and work with outside of the case.
11-30-2017, 01:35 PM #2796 Bullet 20cc, Yamaha OX 250+, 10" jack, labbed 30" Bravo LH w/1.25" exhaust pipes, counter rotating Bob's lower...it goes faster when you spin it the other way...
11-30-2017, 02:31 PM #285000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
WOW Redneck engineering strikes again. LOL
12-01-2017, 11:35 AM #296000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
Make sure nobody pinned the carrier and covered holes with bondo and painted it, been there b4
09-18-2019, 10:50 AM #30New Member
- Sep 2019
- Boca Raton
Hi Capt. Insane-o. I have a very stuck bearing carrier, similar to Bullet. I tried your methods since nothing else was working. Unfortunately the drive shaft now spins when tightening the prop nut to the prop shaft. Do you have any suggestions? Thanks, Rob
Mercury Tech: Prop Shaft Stuck in lower unit with bearing!!!
By Eluder1 in forum Technical DiscussionReplies: 23Last Post: 11-23-2013, 09:47 AM -
By Eluder1 in forum Technical DiscussionReplies: 2Last Post: 11-18-2013, 10:04 PM -
Mercury Tech: 2.4L stuck main bearing. Is block junk???
By JohnBoy in forum Technical DiscussionReplies: 6Last Post: 10-17-2013, 06:04 PM -
Mercury Tech: Removing a stuck bearing carrier....with broken tangs....
By WATERWINGS in forum Technical DiscussionReplies: 15Last Post: 05-11-2011, 09:02 AM
