Results 1 to 2 of 2
    Oct 2017
    Missouri
    300 Promax Not Firing Injectors
    Trying to bring back to life a pair of 98 Promax 300s that have not ran in 14 years. The boat was parked due to one motor melting a wire harness? I have replaced the wire harness, and going thru the VST/fuel system, but the injectors wont fire. good fuel psi. I swapped computers from the other motor that claimed to run with same result. Both Computers Bad? Got spark.
    Yantis, TX
    Double check your grounds first.
    "We, the unwilling, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, for so long, with so little, we are now qualified to do anything with nothing."
  1. Merc 260---not firing the injectors
    By clarkb in forum Technical Discussion
    Last Post: 11-01-2016, 06:52 AM
  2. Merc 260---not firing the injectors
    Last Post: 10-29-2016, 05:16 PM
  3. Promax 200 not firing
    By Ga Boy in forum Technical Discussion
    Last Post: 06-14-2011, 08:59 AM
  4. Mercury Tech: 1999 Mercury Optimax Fuel Injectors Not Firing -- HELP
    By Flat_Out in forum Technical Discussion
    Last Post: 02-08-2011, 05:22 PM
  5. Injectors Not Firing
    By Scott Tharpe in forum Technical Discussion
    Last Post: 03-13-2006, 10:36 PM
Bob's Machine
