Results 1 to 9 of 9
11-08-2017, 02:04 PM #1New Member
- Sep 2017
- Alexandria, VA
- 14
Rebuilding and Debugging by Chris Carson's Marine Service
I wanted to give a shout-out to Chris Carson's Marine Service (CCMS) which recently rebuilt my 2000 Mercury 225 EFI powerhead.
I was on plane at about 4,000RPM and advanced the throttle more. All of a sudden I heard a very loud noise from my outboard as it reached about 4,500RPM. I stopped to investigate and could not determine the exact cause, but I knew it was bad. I dumped a gallon of oil into my fuel tank and nursed it back to the boat ramp with the engine running just above idle speed. I did some diagnosis the next day in my driveway and discovered that the lowest starboard side piston had about 1/8” play like a rod bearing had catastrophically failed.
I did my homework and decided to ship the powerhead from Virginia to Chris Carson's in Key Largo, FL (rather than entrust it to a much closer firm in PA about which I saw some horror stories). Unfortunately, shortly after it got to Key Largo, Hurricane Irma hit. That put a delay into things, but within a couple of weeks, CCMS returned a completely rebuilt powerhead that looked and ran like new. It came back with six, matched .020 over pistons, a set of his fiber reeds, new crank, etc. The parts quality -- even the much-better-than-Sierra base gasket he supplied -- and workmanship seem great. I've got about 10 or 11 hours on the outboard and it's running better than ever. Throttle response is very crisp and I've gained about 2-3mph. I expect that it will serve me well for many years.
Chris Carson determined that a mud dauber wasp nest had been sucked into the engine, doing massive damage to a rod bearing, rod, crank, main seal, piston, and cylinder. He was a tremendous help throughout, answering emails and phone calls and providing all of the advice and tech support anyone could ask for -- even when I was doing other tasks on the midsection and lower unit preparatory to getting the powerhead back (motor mounts, impeller, anodes, tilt & trim motor, etc.).
I could have saved money by finding someone closer to fix it on the cheap, but I'd rather pay to have the work done right the first time than pay to have it done again.
Highly recommended.Last edited by fmaxwell; 11-12-2017 at 12:38 PM.
Glasstream15, Bruce2, outboards4life, Dave Strong, W2F a V-King, capteliminator, litespeed, vnemous, XstreamVking, 30velocity and 1 others liked this post
11-15-2017, 11:34 AM #25000 RPM
- Sep 2001
- ct.
- 173
dobber
don't believe every thing your told.
11-15-2017, 02:01 PM #3Screaming And Flying!
- 14,753
- 381
- 1305
- 5603
- 11035
I would say Cris Carson is beyond reproach russel... Mud DAUBERS do get inside engines. Dirt on the crank would do what?
Mud dauber (or "mud wasp") is a name commonly applied to a number of wasps from either the family Sphecidae or Crabronidae that build their nests from mud. Mud daubers belong to different families and are variable in appearance. Most resemble long, slender wasps about 1-inch (25 mm) in length.[1] The name refers to the nests that are made by the female wasps, which consist of mud molded into place by the wasp's mandibles. Mud daubers are not normally aggressive, but can become belligerent when threatened. Stings are uncommon.Mud dauber Black and yellow mud dauber
Sceliphron caementariumScientific classification Kingdom: Animalia Phylum: Arthropoda Class: Insecta Order: Hymenoptera Suborder: Apocrita Superfamily: Apoidea Families Some Sphecidae and Crabronidae Last edited by XstreamVking; 11-15-2017 at 02:04 PM.
litespeed liked this post
11-15-2017, 03:18 PM #4
I believe it. They get into every damn thing down here. On my boat they get into the little screw holes around the steering wheel bezel and block access to the screws. They also like to get up inside the center console.
FWIW, I can personally vouch for Chris Carson. They did an OUTSTANDING job on rebuilding my little Merc 60 and I would recommend his services to anyone! In fact I did recommend his services to someone over on "The Hull Truth" this morning.
2001 15' Stumpnocker 5 (deep v)
2005 Mercury 60
11-15-2017, 04:01 PM #5Member
- Feb 2006
- Michigan
- 56
- 35
- 125
- 30
11-15-2017, 08:32 PM #65000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
Yeah Chris Carson has helped me out on more than one occasion. I'm lucky to be so close. I recommend him/them to everyone
11-25-2017, 08:55 PM #7
After rebuilding my carbs early this summer. I installed them and never went further. Was waiting on a few other parts. Left the shroud off the motor in a covered carport. What could possibly happen. Turned on the electric fuel pump a few weeks later and all the carbs were pissing fuel. WTF. Took a closer look and those little bastard bee's filled up my air tubes and jet holes. Had to rebuild the carbs again. They do exist.
11-26-2017, 08:02 AM #8
Guy had them plug up his bilge hose. Almost lost his boat when he sprung a leak and his bilge wouldnt pump. When I recommission my Florida boat I check all the hoses and under the cowl and exhaust for the little buggers. Mud Wasps
11-26-2017, 09:59 AM #95000 RPM
- Nov 2013
- PA
- 147
We call them mud wasps up here in Western Pennsylvania. Chris Carson is a top notch motor builder and does what he says he's going to do. He built me a Johnson 150 60 degree carb looper and it runs like a raped ape.
Chris Carson Marine is #1
By themdshrk69 in forum General Boating DiscussionReplies: 13Last Post: 04-15-2013, 12:45 PM -
Chris Carson marine gets it done!!!!
By tedd930 in forum Technical DiscussionReplies: 9Last Post: 10-19-2012, 07:16 AM -
Mercury Tech: Chris Carson Reeds and Brucato Injector service
By gcplowboy in forum Technical DiscussionReplies: 1Last Post: 08-22-2012, 09:50 AM -
Chris Carson Marine = Great products and customer service!
By Mr. Demeanor in forum General Boating DiscussionReplies: 10Last Post: 12-20-2011, 12:11 AM -
For chris carson marine
By daytrader in forum Technical DiscussionReplies: 5Last Post: 03-28-2011, 10:18 AM
