Results 1 to 3 of 3
Thread: Setback help
11-01-2017, 09:34 PM #1Banned
- May 2016
- Bean Station Tn.
- 314
- 53
- 10
- 65
- 50
Setback help
I got a really good deal on a hydraulic jack plate but it only has about 6 in of setback I want to run somewhere between 10 and 12 inches of total setback .... with a boat running in the 90s is it safe to have two plates bolted together... who makes a good one ....or could i have a local shop make me one .... basically what are the do's and don'ts ...i have never ran a setback plate and a jack plate ... my plan was to get one of those fast manual jack plates 12in but I got this hydraulic plate on trade ... so if I can get the set back right I'd like to go ahead and use it any input is appreciated thanks again guys
11-02-2017, 07:21 PM #25000 RPM
- Jun 2002
- Northern Utah
- 454
- 7
- 24
I use a 12 static setback plate with a 6" CMC power plate for a total 18". Works great. Before that I used a 6" manual plate then the 6" power plate. That worked great as well. I have a 21 footer and have a heavy big block DFI engine.
Obviously make sure your transom can handle the setback. Use a 4" or 6" static or manual plate on the boat side and mount the engine to the power plate. Not the other way around. You don't want to have a 6" plate trying to lift 10"-12" of setback. My preference would be to us a static plate rather that a manual adjustable plate. I think the static ones are generally stronger and there is less to worry about.
11-06-2017, 03:00 PM #3
what he said. What I do , works great.
1993 Cougar 21ft MTR Superbender SHO
91eagle thanked for this post
Single engine cat Setback or No setback?
By 2.5-21 in forum Props, Setup, and RiggingReplies: 0Last Post: 02-08-2012, 05:12 PM -
how much is too much setback?
By roycesrolls in forum Props, Setup, and RiggingReplies: 2Last Post: 08-26-2010, 04:56 PM -
OMC Tech: Setback?
By richcraft in forum Technical DiscussionReplies: 16Last Post: 11-09-2009, 12:43 AM -
Setback......how much is too much?
By B.Mac in forum Technical DiscussionReplies: 2Last Post: 02-02-2003, 11:04 AM
