Results 1 to 4 of 4
Thread: Flow thru electric fuel pump
10-27-2017, 07:31 AM #1Member
- Sep 2005
- Maryland
- 35
Anyone know of any pumps that flow thru without being on? Want to cruise without it on and use only on speed runs.....
I had a large Walbro primer pump but it died.
10-27-2017, 08:29 AM #2
I would think if you try to have the standard diaphram pump pull fuel through an electric pump you are running a risk far above just not having an electric fuel pump at all and leave the fuel system stock as designed. Not to mention if you have a fuel filter as well! If you install an electric pump, just use it. IF you dont want to use it all the time leave it off. Just my thoughts.
1973 Viper - sold
1978 Viking - sold
1995 XB02
W2F a V-King, Glasstream15 liked this post
10-27-2017, 08:31 AM #3Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
Sounds like a crazy way to do a fuel system. Build the system right with good parts. I'm always amazed at people that cheap out on fuel systems when the life of the powerhead depends on it
Erik Kiser
10-27-2017, 08:59 AM #4
It claims free flow through... http://ezautoparts.ecrater.com/p/133...tric-fuel-pump
And from the Airtex website ( does not state flow through ) http://www.airtexproducts.com/single...090&id=98756AX maybe call Airtex and ask?
I have this one on my bass rig. I added this to my boat because of the inline fuel and water separator I installed. I did not check for free flow before install... http://www.airtexproducts.com/single-product/?partnumber=E8337&id=98756AX
They both claim 30 GPH free flow. But is not the same as flow through, guess a phone call might be in order.
Here is a recent thread related to your question.... http://www.screamandfly.com/showthre...l-pump-on-Merc
Airtex tech support 1-800-424-7839
Installing Electric fuel pump on Looper, do I need to remove the VRO Pump?
By imq707s in forum Technical DiscussionReplies: 6Last Post: 05-12-2005, 02:21 PM -
electric fuel pump
By outboards4life in forum Technical DiscussionReplies: 5Last Post: 03-22-2004, 03:32 PM -
electric fuel pump, through factory pump, or by pass?
By WATERWINGS in forum Technical DiscussionReplies: 6Last Post: 06-02-2003, 11:38 AM -
Electric Fuel pump-vs- stock pump
By B.Mac in forum Technical DiscussionReplies: 29Last Post: 10-11-2001, 03:49 PM
