Results 1 to 10 of 10
10-17-2017, 08:49 AM #1
Trying to get OMC raker prop to run on mercury?
I'm trying to put my raker prop I had on my OMC on my Mercury the prop slides right on the prop shaft but the problem I'm having is it's hitting the carrier when it slides all the way down it doesn't look like I can use the same thrust Hub as I did on the OMC and I can't seem to find the right one for the mercury has anybody ever tried this is it possible??? it doesn't look like I have enough splines coming out the back end either do I need to have a different Hub pressed into the propeller?
SEEBOLD CHAMPBOAT MERCURY S3000
10-17-2017, 08:57 AM #2
Parker I saw it done once at a prop try out clinic. Can't remember for sure how it done but thought they used a Merc thrust hub. Also used a special nut that was 1/2 as thick as the stock one, thìs was just to try. Sorry I can't remember more but was close to 20yrs ago so can't remember the exact way.
10-17-2017, 12:41 PM #3
I got one off a volvo penta that looks thick enuff ill try this weekend
10-17-2017, 01:38 PM #4
You have a thin nut? Think the thrust hub was a thick on like they had for over the hub props??????
10-17-2017, 04:14 PM #5
the raker seems like its hitting the blowout ring all the way around.......then i barley have any splines out the back with a thick thrust hub.....sucks i dont think its gonna work on a merc
10-17-2017, 04:19 PM #6
10-17-2017, 04:22 PM #7
its hitting the blowout ring , scraping like hell, it might be hitting the carrier nut also.
10-17-2017, 04:29 PM #8The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
What ever you do, don't let it start hitting the gearcase, and scraping it up. In salt water, you know what happens next.
10-17-2017, 04:45 PM #9
Parker take out the blow out ring, looks like the Merc one held in with 4 Allen screws? You ain't going over 90 so you don't need it.
10-18-2017, 08:49 AM #10
Will an OMC 22 RAKER PROP WORK ON MY MERCURY 200?????
By PARKER RABE in forum Technical DiscussionReplies: 15Last Post: 09-25-2017, 05:43 PM -
23p Raker prop w/ Mercury hub
By Slimm in forum PropellersReplies: 1Last Post: 03-10-2014, 05:41 PM -
Raker Prop
By hoodooguru in forum Props, Setup, and RiggingReplies: 3Last Post: 07-17-2011, 07:52 PM -
OMC Tech: What's the difference Raker & Raker II? Prop
By decoy033 in forum Technical DiscussionReplies: 3Last Post: 05-17-2010, 04:30 AM -
Mercury Tech: Raker prop on a Mercury
By captglm in forum Technical DiscussionReplies: 6Last Post: 04-22-2009, 08:23 PM
