Results 1 to 8 of 8
Thread: Mercruiser winterization process
09-12-2017, 12:10 PM #1Junior Member
- Aug 2004
- 19
I own a 1997 Searay 210 with the 5.7 (carb) engine. After being dissatisfied with the Mercury dealer and his winterization process last year, I am planning to do the process this year. I have a simple or dumb question about the process. After running fresh water thru the muffs and then introducing theMercury antifreeze to the system I plan to fog the engine. After the engine shuts down, do I leave the anti freeze in place or do I remove the blue drain plugs and let the anti freeze dran out? Any help is appreciated.
09-12-2017, 01:41 PM #26000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
This is how we do it at the shop...
Get a 5 gallon bucket, put a hole in the side right at the bottom with a ball valve. Run a hose from that to some muffs. Make sure you have a good fuel stabilizer in (also a great time to change oil and filters) Bring the engine to temp dunno g long enough to make sure the treated fuel is in the carb, drain the block down, fill the bucket with AF, put muffs on motor, open valve and start motor, when you get to about a gallon and a half to two gallons left fog motor until empty and cut off motor. Leave the AF In.
09-12-2017, 01:45 PM #36000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
Here is the bucket we made. The bucket will need to be elevated to feed the drive. (Also note this works very well with alpha and OK with bravos)
09-12-2017, 02:23 PM #4Junior Member
- Aug 2004
- 19
Thanks for the advice. I already put non-ethanol fuel in it and ran the fuel additives also. Changed the engine oil and fuel filter. Plan to do the lower unit oil next and then the anti freeze. So many conflicting ideas on how this is done. Dealership that "winterized" it last year just drained the water from the block and unscrewed the clamps and removed the hoses from the thermostat. Left the clamps in a bag on the engine! NO smoke upon initial startup this summer. Merc dealership tells me "We never use anti freeze". The dealership I used many years ago ( they since went out of business) always used anti freeze. How can two certified Mercury Mercruiser dealerships do the same procedure in two opposite ways? And this is on Lake George in upstate NY!!!
09-12-2017, 03:44 PM #56000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
Yeah that's odd....
Also that bucket is good for doing fresh water systems without puttimg anti freeze in Your tank, a.c. systems and other things. Just screw on appropriate fitting and goLast edited by RSWORDS; 09-13-2017 at 05:42 PM.
09-13-2017, 08:58 AM #6
Always drain the block before running the antifreeze through. Make sure water drains from all the petcocks, take a small pick in the boat with you to clean the rust scale and debris out if you have to.
09-13-2017, 09:47 AM #76000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
09-13-2017, 04:56 PM #8
I pull the hoses on the bottom of the exhaust manifolds during draining just to get that last bit of water out. My .02
Winterization Procedure for 225 Optimax
By Just1More in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 0Last Post: 03-11-2007, 02:38 PM -
Winterization Question 2.4
By delawarerick in forum Technical DiscussionReplies: 4Last Post: 10-17-2005, 05:09 PM -
Winterization care
By jlittle in forum Technical DiscussionReplies: 6Last Post: 10-02-2003, 02:06 PM -
Merc Sportjet 90 Winterization question!
By jetlvr in forum Jet Boats, V-Drives and Stern DrivesReplies: 0Last Post: 10-29-2002, 01:16 PM
